| 0002147 | Sketcher | Bug | public | 2015-06-04 15:35 | 2017-09-24 13:41 |
| Reporter | peteruithoven2 | Assigned To | wmayer | ||
| OS | Mac OS X | OS Version | 10.9.5 | ||
| Summary | 0002147: Constraints rename key doesn't work on OS X | ||||
| Description | According to the following issue the F2 key can be used to rename the selected constraint. This doesn't work for me on OS X. 0001380 | ||||
| Steps To Reproduce | A. 1. Select constraint in Constraints window. 2. Press fn + F2 key. (Normally F2 is used by OS for brightness control) B. 1. Select constraint in Sketch window. 2. Press fn + F2 key. | ||||
| Additional Information | OS: Mac OS X Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4671 (Git) Branch: releases/FreeCAD-0-15 Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | macOS | ||||
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19779 |
Confirmed, but in OS X to rename such a thing you just have to push enter (renaming a file for instance) and it works just fine. |
Verified that pressing Enter (which is default on macOS) allows to rename a constraint. On other OS the shortcut is F2. |
| 2015-06-04 15:35 | peteruithoven2 | New Issue | |
| 2017-01-10 17:32 | Kunda1 | Note Added: 0007612 | |
| 2017-01-14 08:44 | nemesis | Note Added: 0007756 | |
| 2017-01-19 13:12 | Kunda1 | Tag Attached: MacOSX | |
| 2017-01-19 20:17 | Kunda1 | Relationship added | related to 0001380 |
| 2017-01-19 20:17 | Kunda1 | Description Updated | |
| 2017-09-24 13:41 | wmayer | Assigned To | => wmayer |
| 2017-09-24 13:41 | wmayer | Status | new => closed |
| 2017-09-24 13:41 | wmayer | Resolution | open => no change required |
| 2017-09-24 13:41 | wmayer | Fixed in Version | => 0.16 |
| 2017-09-24 13:41 | wmayer | Note Added: 0010168 | |
