| 0002156 | PartDesign | Bug | public | 2015-06-13 19:42 | 2017-07-11 20:09 |
| Reporter | drei | Assigned To | abdullah | ||
| Platform | 64 bit | OS | GNU/Linux | OS Version | Arch Linux |
| Summary | 0002156: Sketcher Visualization fails to represent sketch properly | ||||
| Description | This is one of several bugs found from the attached file. When opening the file, one can see a trapezoid object with a certain size. After editing the sketch, deleting a redundant constraint and closing the sketch, the Sketch view changes in both scale and position. No output whatsoever in either Python Console, command line terminal or the Report View. | ||||
| Steps To Reproduce | Open the file. Activate hidden sketch. Note the differences in size and position of the sketches before and during edit mode. | ||||
| Additional Information | Original thread: http://forum.freecadweb.org/viewtopic.php?f=3&t=11337&p=91207 Reproducible in OS: Windows 8.1 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.15.4671 (Git) Branch: releases/FreeCAD-0-15 Hash: 244b3aef360841646cbfe80a1b225c8b39c8380c Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 and OS: Linux Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5086 (Git) Build type: Unknown Branch: master Hash: 4f5534a87a7e2d224022ff98729a341bf57e7f9e Python version: 2.7.10 Qt version: 4.8.7 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 | ||||
| related to | 0002157 | closed | Pad results in a triangle instead of a trapezoid |
I can confirm this issue. I've attached some screenshots that show the problem: 'Sketch_Opened.png' shows the results of clicking on the old sketch in the object tree. The two sketches should be the same size, but as is seen in this screenshot they are not. I will explore this issue. OP: Can you provide step-by-step instructions on how you produced the two over-constrained sketches? |
You can force such a behaviour quite easily. Start with a sketch and set non-conflicting constraints. Leave edit mode to create the actual shape from the geometries and constraints. Now start editing the sketch again, change some datum constraints and add further conflicting constraints. The solver will fail and won't update the last valid shape. Save the project, leave edit mode and close the document. After reopening the project you very likely will have some inconsistencies. When you run the ForceRecompute macro you see that the sketch objects are actually invalid. Maybe to make this more obvious we should save any flags of a document object into the project file. When loading the project the user will immediately see that something is wrong. In the concrete example one thing is for sure: the shape of Sketch001 you see is definitely wrong (too big) because when you edit it the length constraint is set to 26mm. However, when measuring the length of the shape you get a value of 40.33 mm. When you edit the sketch the solver does its best and at least shows a trapezoid of the correct size. |
@Abdullah this one was related to 0002157 what should we do with it? |
It is similar, but not the same. Here the problem was that the file, when saved, had problems. However, "problems" (flags in what Werner says above) do not get marked when saving. So, when restoring, they do not get restored. So the "problems" do not get detected until there is a recompute. Here, a priori, the only decent solution I can think of is the one indicated by Werner, i.e. to store (the/some of the) flags of a document object into the project file. I do not know if this would generate any other problems. The alternative would be to recompute on loading, which I don't think it is acceptable. I will give it a go... |
PR: https://github.com/FreeCAD/FreeCAD/pull/793 |
https://github.com/FreeCAD/FreeCAD/commit/749d666099ce5d201e67917d491c9dad2c0ccf32 |
| 2015-06-13 19:42 | drei | New Issue | |
| 2015-06-13 19:42 | drei | File Added: bugs_Basic_Part_01.FCStd | |
| 2016-05-10 01:36 | ezzieyguywuf | File Added: Sketch_Opened.png | |
| 2016-05-10 01:36 | ezzieyguywuf | File Added: Sketch001_Opened.png | |
| 2016-05-10 01:37 | ezzieyguywuf | Note Added: 0007076 | |
| 2016-05-10 01:48 | ezzieyguywuf | Note Edited: 0007076 | |
| 2016-05-11 09:19 | wmayer | Note Added: 0007079 | |
| 2017-01-14 01:36 | Kunda1 | Relationship added | related to 0002157 |
| 2017-02-02 14:38 | Kunda1 | Tag Attached: #pending | |
| 2017-05-30 21:50 | Kunda1 | Note Added: 0009201 | |
| 2017-05-31 13:09 | abdullah | Note Added: 0009220 | |
| 2017-05-31 13:09 | abdullah | Assigned To | => abdullah |
| 2017-05-31 13:09 | abdullah | Status | new => assigned |
| 2017-05-31 14:18 | abdullah | Note Added: 0009223 | |
| 2017-06-01 11:15 | wmayer | Status | assigned => closed |
| 2017-06-01 11:15 | wmayer | Resolution | open => fixed |
| 2017-06-01 11:15 | wmayer | Fixed in Version | => 0.17 |
| 2017-06-01 11:15 | wmayer | Note Added: 0009239 | |
| 2017-06-21 20:37 | Kunda1 | Changeset attached | => FreeCAD master 749d6660 |
| 2017-07-11 20:09 | Kunda1 | Tag Detached: #pending |
