| 0002164 | Arch | Bug | public | 2015-06-21 11:54 | 2017-02-15 08:40 |
| Reporter | more11 | Assigned To | |||
| Platform | Dell XPS | OS | Windows 7 | OS Version | x64 professional |
| Summary | 0002164: Unable to create edge linked to external geometry when creating a window | ||||
| Description | Edge to external geometry is not saved when closing window sketch. | ||||
| Steps To Reproduce | I select a surface of a wall and choose the window tool. It is possible to create an edge to external geometry and make constraints between the window and the edge. When closing and reopening the sketch, the edge and the constraints are gone. I could not reproduce the error using macro, there is another error when executing the macro. Maybe the macro is of help. Open the drawing https://dl.dropboxusercontent.com/u/106944188/FreeCAD/window/plan3.FCStd Run the macro https://dl.dropboxusercontent.com/u/106944188/FreeCAD/window/cre_window.FCMacro | ||||
| Additional Information | OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5113 (Git) Build type: Release Branch: master Hash: 074d5d7f11239ab958e0472150bed25e9617a256 Python version: 2.7.8 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
This is a current limitation of the Window object (walls depend on it, and it depends on its sketch, so that sketch cannot depend on the wall). Unless we find another concept to make windows create holes in walls automatically, that doesn't create dependency, it won't be solved anytime soon. Unfortunately at the moment there is nothing that can be done to solve this issue. |
| 2015-06-21 11:54 | more11 | New Issue | |
| 2015-06-21 15:49 | yorik | Note Added: 0006217 | |
| 2015-06-21 15:49 | yorik | Note Edited: 0006217 | |
| 2017-01-23 21:41 | Kunda1 | Project | FreeCAD => Arch |
| 2017-02-15 08:40 | kkremitzki | Status | new => closed |
| 2017-02-15 08:40 | kkremitzki | Resolution | open => won't fix |
