| 0002167 | FreeCAD | Bug | public | 2015-06-23 00:31 | 2019-09-11 21:21 |
| Reporter | vitorvitorvitor88 | Assigned To | abdullah | ||
| Platform | Windows 7 64 bits | OS | Windows | OS Version | Windows |
| Summary | 0002167: Datum 10.5295 mm for the constraint with index 8 is invalid | ||||
| Description | Impossible to assign the dimension of a line between two points using line length constraint. And the clicking order (point picking turning green after one another ) influences the sign of the dimension reported when the crash windows appears. If i pick the greater X valued point first and then the smaller, the error windows reported sign is negative otherwise it's positive. | ||||
I can not replicate the problem. I mean: I can make a rectangle and use the Distance constraint (the two sided arrow icon) to set a line length by selecting any of its points first and then the other. No matter if they have a higher X value or a lower one. If you still have this issue, please attach the file where this behaviour is shown, so that I can replicate. |
| 2015-06-23 00:31 | vitorvitorvitor88 | New Issue | |
| 2015-06-23 00:31 | vitorvitorvitor88 | File Added: free_cad.png | |
| 2015-07-20 04:17 | abdullah | Assigned To | => abdullah |
| 2015-07-20 04:17 | abdullah | Status | new => assigned |
| 2015-07-20 04:20 | abdullah | Note Added: 0006253 | |
| 2016-01-08 16:04 | abdullah | Status | assigned => closed |
| 2016-01-08 16:04 | abdullah | Resolution | open => unable to reproduce |
| 2016-01-08 16:04 | abdullah | Fixed in Version | => 0.16 |
| 2019-09-11 21:21 | Kunda1 | Relationship added | related to 0004123 |
