| 0002178 | FreeCAD | Bug | public | 2015-07-02 17:27 | 2017-01-31 18:19 |
| Reporter | wtaber | Assigned To | |||
| Platform | Lenovo laptop | OS | Windows 8 | OS Version | 8.1 |
| Summary | 0002178: Fillet of edges extends further than it should | ||||
| Description | The ability to fillet an edge or edges produces mixed results. I can fillet and edge and sometimes an edge that came to the same point. However, if I continue to select edges in wireframe, I see that the fillet exends beyond the intended edge and wraps around the 90 degree common corner. My expectation is that when I pick and edge that I could "hand file" that the adjacent edge should not automatically be "filed". I need to control the fillet to individual edges. This is a deal breaker for me. | ||||
| Steps To Reproduce | Create a rectangular block and chamfer an edge. The pick edges in wireframe and start adding a fillet to a selected edge. The selected edge should receive the fillet, but NOT adjacent edges that are at 90 degrees and happen to share a common point. | ||||
Which workbench are you referring to? |
@wtaber please answer 0002178:0006252 and also post your Help > About FreeCAD > Copy to clipboard |
No response from @wtaber Resolving this ticket as 'unable to reproduce' |
The described procedure is quite vague in what exactly should be done. But nevertheless it's known behaviour that in certain cases a not selected edge is filleted too in order to create a valid geometry. |
| 2015-07-02 17:27 | wtaber | New Issue | |
| 2015-07-20 04:05 | abdullah | Note Added: 0006252 | |
| 2017-01-17 06:02 | Kunda1 | Note Added: 0007835 | |
| 2017-01-17 06:02 | Kunda1 | Status | new => feedback |
| 2017-01-26 01:22 | Kunda1 | Note Added: 0007994 | |
| 2017-01-26 01:22 | Kunda1 | Status | feedback => resolved |
| 2017-01-26 01:22 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-01-26 01:22 | Kunda1 | Assigned To | => Kunda1 |
| 2017-01-26 01:22 | Kunda1 | Assigned To | Kunda1 => |
| 2017-01-31 18:19 | wmayer | Note Added: 0008131 | |
| 2017-01-31 18:19 | wmayer | Status | resolved => closed |
| 2017-01-31 18:19 | wmayer | Resolution | unable to reproduce => not fixable |
