| 0002183 | FreeCAD | Bug | public | 2015-07-04 15:07 | 2017-02-09 17:48 |
| Reporter | quick61 | Assigned To | wmayer | ||
| Summary | 0002183: Mesh View . Use Bounding-Box Not Working For Flat Lines | ||||
| Description | Use bounding-box for highlighted or selected meshes not working for Mesh view when Display mode is set to Flat Lines. Nether pre-selection or selection bounding-box shows. It does show in all other display modes. | ||||
| Steps To Reproduce | Goto Edit > Preferences > Display > Mesh view, and check on the "Use bounding-box for highlighted or selected meshes". Create or load a part, a basic solid will do, Sphere works well. Hovering the mouse over the part or clicking on it gives you a bounding box, pe-select or select. Select the mesh and change it's Display Mode. The bounding-box works for Shaded, Wireframe, and Point, but does not work for Flat Lines. | ||||
| Additional Information | In version 0.14.3705, selected mesh shows bounding-box in Flat Lines display, but there is no pre-select. From 0.15.4671 release on to 0.16.5171 development, there is no pre-select or selected bounding-box. OS: Kubuntu 14.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5171 (Git) Build type: Release Branch: master Hash: 6c32edfb8c8f95fb51f0cba694fc46c53fb0059d Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=20031 |
@cox could still reproduce this bug (https://forum.freecadweb.org/viewtopic.php?p=156698#p156698) |
The selection node (class SoFCSelection) reverts the pre-selection when the same instance is used multiple times in the graph. For the Flat & Lines mode this was the case. The solution is to use an additional group node to keep the mesh data and use this as replacement for the selection node. |
FreeCAD: master 9925e902 2017-02-09 17:30:48 Details Diff |
issue 0002183: Mesh View . Use Bounding-Box Not Working For Flat Lines |
Affected Issues 0002183 |
| mod - src/Mod/Mesh/Gui/ViewProvider.cpp | Diff File | ||
| mod - src/Mod/Mesh/Gui/ViewProvider.h | Diff File | ||
| mod - src/Mod/Mesh/Gui/ViewProviderMeshFaceSet.cpp | Diff File | ||
| 2015-07-04 15:07 | quick61 | New Issue | |
| 2017-01-19 00:25 | Kunda1 | Note Added: 0007870 | |
| 2017-01-29 10:37 | wmayer | Assigned To | => wmayer |
| 2017-01-29 10:37 | wmayer | Status | new => assigned |
| 2017-01-29 14:16 | Kunda1 | Note Added: 0008070 | |
| 2017-02-09 17:31 | wmayer | Changeset attached | => FreeCAD Master master 9925e902 |
| 2017-02-09 17:47 | wmayer | Note Added: 0008253 | |
| 2017-02-09 17:48 | wmayer | Status | assigned => closed |
| 2017-02-09 17:48 | wmayer | Resolution | open => fixed |
| 2017-02-09 17:48 | wmayer | Fixed in Version | => 0.17 |
