| 0002187 | FreeCAD | Bug | public | 2015-07-09 07:27 | 2019-03-06 11:28 |
| Reporter | frwi5432 | Assigned To | Chris_G | ||
| Platform | 64-bit | OS | Windows | OS Version | 7 |
| Summary | 0002187: Sweep tool fails with Frenet=True on special Wire created from Section | ||||
| Description | The Sweep tool creates an ugly structure when using Frenet=True, while the result with Frenet=False is ok. The attached macro creates with Draft.upgrade a special Wire from a Section which was built out of a Revolve and a Sweep. | ||||
| Steps To Reproduce | Run the macro once with Frenet=False and once with Frenet=True. This can be changed at the beginning of function create_geometries(). A t t e n t i o n : The calculation might take some minutes. | ||||
| Additional Information | See also http://forum.freecadweb.org/viewtopic.php?f=22&t=11705&p=94102#p94102 | ||||
| Tags | sweep | ||||
| related to | 0002509 | confirmed | Part | Sweep using bezier curve bug |
How can I delete here an attachment? |
Bumped forum thread: https://forum.freecadweb.org/viewtopic.php?f=22&t=11705&p=156568#p156568 |
[quote="Chris_G"]Hi, The red spiral, in the above picture, is made of 4 BsplineCurves of degree 1 : Edge 1, with 1026 poles Edge 2, with 1026 poles Edge 3, with 2463 poles Edge 4, with 1003 poles If I try to pick a normal somewhere on the first edge, I get :
That should explain why Frenet mode is failing.The solution is probably to discretize the faulty wire and recreate a clean BSplineCurve by interpoation or approximation. But is it a FreeCAD bug ? Maybe the Sweep tool should check the sweep path more strictly ?[/quote]
@wmayer can you offer an opinion? |
@yorik ping |
@frwi5432 do you mind uploading the macro and image again? |
Hello, attached you'll find the macro and the image. Hope that helps. Kind regards, Willy |
Chris_G responded to the thread: https://forum.freecadweb.org/viewtopic.php?f=22&t=11705&start=10#p203254 UR_ responded as well: https://forum.freecadweb.org/viewtopic.php?f=22&t=11705&start=10#p204208
I think this one can be closed. Fixed by this PR : https://github.com/FreeCAD/FreeCAD/pull/1507 |
@Chris_G thanks! Sorry I can't attribute fix to you since you're not a developer per the tracker. I'll see what w can do about that https://github.com/FreeCAD/FreeCAD/commit/be96fcc62d7b2f31996e491f4737ec5f8bc529ac https://github.com/FreeCAD/FreeCAD/commit/f3ac51d9b7ca0ccca68879d31d69812fdebb7a9c |
| 2015-07-09 07:27 | frwi5432 | New Issue | |
| 2015-07-09 07:27 | frwi5432 | File Added: Path0904.FCMacro | |
| 2015-07-09 08:03 | frwi5432 | File Added: Path0904.jpg | |
| 2015-07-09 08:10 | frwi5432 | Note Added: 0006246 | |
| 2017-01-19 13:11 | Kunda1 | Tag Attached: #pending | |
| 2017-01-28 13:23 | Kunda1 | Note Added: 0008054 | |
| 2017-01-28 13:23 | Kunda1 | Status | new => feedback |
| 2017-01-28 13:23 | Kunda1 | Tag Attached: sweep | |
| 2017-02-17 13:47 | Kunda1 | Relationship added | related to 0002509 |
| 2017-03-14 11:45 | Kunda1 | Priority | high => normal |
| 2017-03-14 11:45 | Kunda1 | Severity | major => minor |
| 2017-05-13 12:29 | Kunda1 | Note Added: 0008981 | |
| 2017-05-13 12:29 | Kunda1 | Note Added: 0008982 | |
| 2017-07-03 21:20 | Kunda1 | Note Added: 0009661 | |
| 2017-08-23 11:58 | Kunda1 | Note Added: 0009997 | |
| 2017-09-08 10:25 | frwi5432 | File Added: Path0904-2.FCMacro | |
| 2017-09-08 10:25 | frwi5432 | File Added: Path0904-2.jpg | |
| 2017-09-08 10:25 | frwi5432 | Note Added: 0010090 | |
| 2017-09-08 10:25 | frwi5432 | Status | feedback => new |
| 2018-03-03 10:40 | Kunda1 | Target Version | => 0.18 |
| 2018-03-03 10:43 | Kunda1 | Note Added: 0010988 | |
| 2018-06-14 05:32 | Chris_G | Note Added: 0011431 | |
| 2018-06-14 13:12 | Kunda1 | Status | new => closed |
| 2018-06-14 13:12 | Kunda1 | Resolution | open => fixed |
| 2018-06-14 13:12 | Kunda1 | Fixed in Version | => 0.18 |
| 2018-06-14 13:12 | Kunda1 | Note Added: 0011434 | |
| 2018-08-26 15:20 | Kunda1 | Tag Detached: #pending | |
| 2019-03-06 11:28 | Kunda1 | Assigned To | => Chris_G |
