| 0002242 | Path | Bug | public | 2015-09-08 20:05 | 2017-02-15 06:18 |
| Reporter | jonnor | Assigned To | kkremitzki | ||
| Summary | 0002242: Path: Offset profile of circle(s) causes exceptions | ||||
| Description | Couple of issues experienced when trying to mill out a part with circles. Selecting a single circle edge (or face) and using the libarea/offset profile, I get an exception. There is a different exception if I select multiple. All seem related to expectations that there be multiple edges and/or vertices. See attached example project for real-life example. | ||||
| Steps To Reproduce | * Open new document * Add some circular geometry (example: Sketch with circle) * Select one or more circle edge * Invoke Path Profile using libarea | ||||
| Additional Information | Tested on git master, commit 3c10cd1af2bb702953f3cff8fdb3c6e6df1bd7b5 Selecting a circular face (like top of cylinder), and using the (non-offset) Profile seems to work. But there are several cases where such a face is not existant. For instance when a part has circular hole(s) in it (with size is larger than tool size so cannot drill). -- When selecting a single edge: Traceback (most recent call last): File "/home/jon/contrib/code/freecad/Mod/Path/PathScripts/PathKurve.py", line 145, in execute self.final_depth,self.use_CRC,obj.Direction,self.startpt,self.endpt) File "/home/jon/contrib/code/freecad/Mod/Path/PathScripts/PathKurveUtils.py", line 249, in makePath curve = makeAreaCurve(edges,direction,startpt, endpt) File "/home/jon/contrib/code/freecad/Mod/Path/PathScripts/PathKurveUtils.py", line 57, in makeAreaCurve vlist,edgestart,common = PathSelection.Sort2Edges([cleanededges[0],cleanededges[1]]) <type 'exceptions.IndexError'>: list index out of range Profile: list index out of range When selecting multiple edges: 'NoneType' object is not iterableRunning the Python command 'Path_Profile' failed: Traceback (most recent call last): File "/home/jon/contrib/code/freecad/Mod/Path/PathScripts/PathProfile.py", line 213, in Activated selection = PathSelection.multiSelect() File "/home/jon/contrib/code/freecad/Mod/Path/PathScripts/PathSelection.py", line 203, in multiSelect vlist,edgestart,edgecommon=Sort2Edges(edgelist) File "/home/jon/contrib/code/freecad/Mod/Path/PathScripts/PathSelection.py", line 51, in Sort2Edges a1 = e0.Vertexes[1] list index out of range | ||||
OP please retest on 0.16 Also as an FYI when you post ticket in the future please add the contents of Help > About FreeCAD > Copy to clipboard Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20163 |
Can't replicate the exception. I get some bogus paths depending on settings but that's a broader problem we're fighting in a number of areas unrelated to this issue. Unless OP weighs in, recommend close. |
In that case, I'm resolving issue (that way OP can still re-open). Thanks @sliptonic |
| 2015-09-08 20:05 | jonnor | New Issue | |
| 2015-09-08 20:05 | jonnor | File Added: baseclamp-cnc.fcstd | |
| 2017-01-23 21:26 | Kunda1 | Note Added: 0007926 | |
| 2017-01-23 21:26 | Kunda1 | Status | new => feedback |
| 2017-01-23 21:26 | Kunda1 | Tag Attached: #pending | |
| 2017-01-31 13:13 | Kunda1 | Project | FreeCAD => Path |
| 2017-01-31 23:03 | sliptonic | Note Added: 0008139 | |
| 2017-02-02 13:07 | Kunda1 | Note Added: 0008168 | |
| 2017-02-02 13:07 | Kunda1 | Status | feedback => resolved |
| 2017-02-02 13:07 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-02-02 13:07 | Kunda1 | Assigned To | => Kunda1 |
| 2017-02-02 13:07 | Kunda1 | Assigned To | Kunda1 => |
| 2017-02-02 13:07 | Kunda1 | Tag Detached: #pending | |
| 2017-02-15 06:17 | kkremitzki | Status | resolved => closed |
| 2017-02-15 06:18 | kkremitzki | Assigned To | => kkremitzki |
