| 0002246 | PartDesign | Bug | public | 2015-09-09 20:43 | 2017-03-22 01:07 |
| Reporter | severoraz | Assigned To | kkremitzki | ||
| Summary | 0002246: Polar pattern of overlapping pocket feature produces several solids (negatives of the pocket) | ||||
| Description | I have sketched a feature to pocket out of a circular solid. The pocket needs to be repeated into a polar pattern, and for the amount of repetitions needed, repetitions of the feature fit tightly. However after applying the polar pattern, several repetitions appear as solids instead of pockets, each seemingly randomly. EDIT: Scratch that, the behavior is quite unpredictable (in the attached file, the problem is different from the described above: the main solid appears hollowed out for no reason, and an "unpocket" extends infinitely below the XY plane). I think this may be due to a slight overlap, so slight that the overlapping warning is never triggered. | ||||
| Steps To Reproduce | I don't know if this is easily reproducible, I better attach the file. | ||||
| duplicate of | 0002028 | closed | kkremitzki | Polar Pattern feature leaves faces missing |
| duplicate of | 0002072 | closed | kkremitzki | Polar pattern of slot pocketed from curved faces fails for certain number of occurrences |
| 2015-09-09 20:43 | severoraz | New Issue | |
| 2015-09-09 20:43 | severoraz | File Added: model.fcstd | |
| 2017-01-12 14:15 | Kunda1 | Relationship added | related to 0002028 |
| 2017-01-13 22:32 | Kunda1 | Relationship replaced | duplicate of 0002028 |
| 2017-01-14 13:39 | Kunda1 | Relationship added | duplicate of 0002072 |
| 2017-03-22 01:07 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-22 01:07 | kkremitzki | Status | new => closed |
| 2017-03-22 01:07 | kkremitzki | Resolution | open => fixed |
| 2017-03-22 01:07 | kkremitzki | Fixed in Version | => 0.17 |
