| 0002028 | PartDesign | Bug | public | 2015-03-27 06:49 | 2017-03-22 01:07 |
| Reporter | Don Lawn | Assigned To | kkremitzki | ||
| Platform | AMD Quad Core | OS | Windows | OS Version | 7 |
| Summary | 0002028: Polar Pattern feature leaves faces missing | ||||
| Description | When creating a polar pattern from a sample (gear tooth wedge), it works fine for 2 occurrences, but leaves faces missing on occurrences, for 3 or more occurrences | ||||
| Steps To Reproduce | Open the sample file "20 tooth GT2 pulley" attached. Open the details dialog for the part "Polar Pattern" - multiple teeth" Set the number of occurrences to "2" and tab out out of the field. displayed part is correct. Set the number of occurrences to "3" and tab out The displayed part is missing side faces from the third occurrence. | ||||
| Additional Information | Any number greater than three also causes the problem for all except the fist two occurrence. | ||||
| related to | 0002248 | closed | kkremitzki | PartDesign | Overlaps in polar patterns shouldn't always be errors |
| has duplicate | 0002072 | closed | kkremitzki | PartDesign | Polar pattern of slot pocketed from curved faces fails for certain number of occurrences |
| has duplicate | 0002246 | closed | kkremitzki | PartDesign | Polar pattern of overlapping pocket feature produces several solids (negatives of the pocket) |
| has duplicate | 0002637 | closed | kkremitzki | FreeCAD | Inconsistent 3D after removing operation (pocket or boolean operation) |
PS. bad structure can be confirmed using the "Analyse Geometry for Errors" feature in the Part toolbox. |
I can NOT repeat this with "OCC version: 6.8.0.oce-0.17-dev" That being said, The pattern is creating a non-manifold condition. This is bad for boolean operations. A point on the sketch shouldn't coincide with the rotation axis. |
I'll try trimming out the centre point. |
Don, even if you trim out the center point, each of your occurrences will share two faces with the occurrences on both sides. This is bad practice and is a recipe for trouble. In this specific case you should use subtractive features rather than additive ones. It would be much better to pad a circle to create a cylinder, then make a cutout of a tooth using the Pocket feature. This way the polar pattern will surely succeed without errors. |
Removing the centre point fixes it ok. Normandc - thanks, subtraction would work, but would take about the same effort, which is significant because I am ultimately working up to about 150 teeth. I must say, that I don't understand why the overlap of occurrences is such a problem. In normal construction, it is common to either get an accurate face match using sketches on faces, OR, to overlap parts and then group them into a single part. I cannot think of any other operation that has problems with overlapped parts, so I don't see why the overlap of occurrences in a polar pattern should be a problem. Each occurrence should be a complete solid with all surfaces specified, whether there is underlap of overlap. Even difficult special cases such as the origin point should be handled in some manner internally, rather than breaking the occurrences. If the error dialog regarding overlap could be changed to give an option of accepting the overlap, then I would be able to complete the operation, and group all of the occurrences together to make a a single part from them all, using the part menu item. Of course, there would then be the problem of the lack of a support base for the occurrences, except that this isn't really a problem if they are all to be grouped later anyway. In fact, if FreeCad detects that there is overlap, then it could simply bypass the check for a support base, and automatically group the occurrences into a single part. This approach would result in a) removal of two annoying errors that have to be investigated. b) avoidance of the centre-point issue c) no need for you to support people like me who don't understand d) two ways to produce my gear wheel - either by addition or subtraction e) a more intuitive option for usage. Just my opinion - its a great product anyway. Since there are standard workarounds (avoid the centrepoint, or use subtraction), then I am happy for you to close of downgrade this issues as you see fit. However, if you do, could I volunteer to add some text to the online help and wiki to steer others around this rock? |
PS. I realise that it will be almost a mathematical impossibility to make the multiple occurrences line up face to face exactly, due to the nature of Pi. That is one reason I would naturally try to go for the overlap option, as underlap dos not make a solid piece, and would need a support base. |
I truly understand what you mean about overlapping being considered as a problem. I have reported the bug 0002248 to suggest that this be handled differently. I also had reported bug 0002246 and it seems to be a duplicate of this issue. I also found bug 0002072 to be very similar to this one; I think both bugs 0002246 and 0002072 are duplicates of 0002028 (present bug). |
@wmayer shall i merge 0002072 & 0002246 with this ticket? |
Linked 0002637 to this ticket as well. |
The file indeed looks broken, but I was not able to reproduce it with PDN. See file attached. There might be some minute details left so don't close this yet. Edit: could simply get rid of the issue by using "Part Design->Migrate" on the file posted by OP. version: OS: Ubuntu 16.04.2 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.10540 (Git) Build type: None Branch: master Hash: 2c9d5e30108a2a34a7f11cfad3d9c323e5577ce1 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 |
| 2015-03-27 06:49 | Don Lawn | New Issue | |
| 2015-03-27 06:49 | Don Lawn | File Added: 20 tooth GT2 Pulley.FCStd | |
| 2015-03-27 07:03 | Don Lawn | Note Added: 0005947 | |
| 2015-03-27 16:31 | tanderson69 | Note Added: 0005948 | |
| 2015-03-30 05:07 | Don Lawn | Note Added: 0005957 | |
| 2015-04-03 03:28 | normandc | Note Added: 0005962 | |
| 2015-04-04 11:34 | Don Lawn | Note Added: 0005964 | |
| 2015-04-04 11:36 | Don Lawn | Note Added: 0005965 | |
| 2015-09-10 06:41 | severoraz | Note Added: 0006377 | |
| 2015-09-10 06:42 | severoraz | Note Edited: 0006377 | |
| 2017-01-12 14:12 | Kunda1 | Relationship added | related to 0002248 |
| 2017-01-12 14:15 | Kunda1 | Note Added: 0007669 | |
| 2017-01-12 14:15 | Kunda1 | Relationship added | related to 0002072 |
| 2017-01-12 14:15 | Kunda1 | Relationship added | related to 0002246 |
| 2017-01-13 22:32 | Kunda1 | Relationship replaced | has duplicate 0002072 |
| 2017-01-13 22:32 | Kunda1 | Relationship replaced | has duplicate 0002246 |
| 2017-01-28 11:59 | Kunda1 | Relationship added | has duplicate 0002637 |
| 2017-01-28 12:00 | Kunda1 | Note Added: 0008046 | |
| 2017-03-21 19:33 | jnxd | File Added: issue2028_OK.fcstd | |
| 2017-03-21 19:33 | jnxd | Note Added: 0008683 | |
| 2017-03-21 19:39 | jnxd | Note Edited: 0008683 | |
| 2017-03-22 01:07 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-22 01:07 | kkremitzki | Status | new => closed |
| 2017-03-22 01:07 | kkremitzki | Resolution | open => fixed |
| 2017-03-22 01:07 | kkremitzki | Fixed in Version | => 0.17 |
