| 0002264 | Sketcher | Bug | public | 2015-09-14 06:41 | 2017-07-15 11:00 |
| Reporter | severoraz | Assigned To | abdullah | ||
| Summary | 0002264: Construction lines should be rendered below non-construction lines | ||||
| Description | Construction lines should be rendered below non-construction lines because their use is secondary and otherwise it becomes difficult to work with sketch lines that overlap construction lines. | ||||
| Steps To Reproduce | 1. Draw a line 2. Draw a line on top of the previous line 3. Set either line to be a construction line 4. Observe how the construction line is rendered over the sketch line | ||||
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20164 |
What I'm getting now is that the first sketched geometry will always stay on top of any other geometry that gets added afterwards, independent of whether the first sketched geometry is construction or non-construction. Whether the new behaviour is more desirable or intended is another matter... OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 and OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.9747 (Git) Build type: None Branch: master Hash: f5c0f579cbd7ce668727f8835946e4e9abc0eec6 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
@nemesis writes > [phenomena described is still valid] but maybe construction lines just need to be dot dash lines? that's maybe more a matter of choice than a bug I guess. |
@abdullah wrote: What is drawn on top of what depends on what you want to achieve. Drawing construction on top of normal is as bad a solution as doing it otherwise, just because there are cases where one is needed an other where the other is needed. I am currently working out a more general solution, so I assign this to myself. |
Abdullah committed fix in c:FreeCAD:937c6179: (but changeset hasn't been updated yet). Resolving. Note: please don't close without attaching commit to ticket |
https://github.com/FreeCAD/FreeCAD/commit/937c6179e2aa960d94279d634957a796af241d42 |
| 2015-09-14 06:41 | severoraz | New Issue | |
| 2017-01-23 21:29 | Kunda1 | Note Added: 0007927 | |
| 2017-01-23 21:30 | Kunda1 | Tag Attached: #pending | |
| 2017-01-24 05:02 | normandc | Note Added: 0007945 | |
| 2017-01-25 12:10 | Kunda1 | Note Added: 0007974 | |
| 2017-04-26 11:22 | Kunda1 | Project | PartDesign => Sketcher |
| 2017-04-26 11:23 | Kunda1 | Assigned To | => abdullah |
| 2017-04-26 11:23 | Kunda1 | Status | new => assigned |
| 2017-04-26 11:23 | Kunda1 | Note Added: 0008772 | |
| 2017-04-26 11:29 | Kunda1 | Note Added: 0008773 | |
| 2017-04-26 11:30 | Kunda1 | Status | assigned => resolved |
| 2017-04-26 11:30 | Kunda1 | Resolution | open => fixed |
| 2017-04-26 11:30 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-07-15 10:57 | Kunda1 | Tag Detached: #pending | |
| 2017-07-15 11:00 | Kunda1 | Status | resolved => closed |
| 2017-07-15 11:00 | Kunda1 | Note Added: 0009760 |
