0002270SketcherBugpublic2016-02-28 11:17
ReporterHoWil Assigned To
PrioritynormalSeveritymajorReproducibilityhave not tried
Status closedResolutionfixed
Fixed in Version0.16
Summary0002270: Grid size cant be set below 0,2 mm
DescriptionGrid size cant be set below 0,2 mm. Units like µm are not accepted.
But it does not work for the grid size in the 'Edit controls' dialogue in the sketcher nor in the preferences.
Tested under 0.16 5560 (Git) on Linux 14.04.3 x64
Additional InformationThe issue was discussed in the forum, see http://forum.freecad.org/viewtopic.php?p=100089#p100089 .
Relationships
related to 0002195 closedeivindkvedalen Expressions Input validator doesn't allow comma as decimal separator inside input fields a second time
There are no notes attached to this issue.
Related Changesets
FreeCAD: master a1f16cab
2016-02-25 16:00:01
yorik
Details Diff
Merge pull request 0000101 from wood-galaxy/sketcher-micro-sizing
Sketcher : Allow µm in sketcher grid size
Affected Issues
0002270
mod - src/Mod/Sketcher/Gui/TaskSketcherGeneral.ui Diff File
2015-09-19 15:40 HoWil New Issue
2015-09-19 17:09 wmayer Relationship added related to 0002195
2016-02-28 11:15 wmayer Changeset attached => FreeCAD Master master a1f16cab
2016-02-28 11:17 wmayer Status new => closed
2016-02-28 11:17 wmayer Resolution open => fixed
2016-02-28 11:17 wmayer Fixed in Version => 0.16
