| 0002195 | Expressions | Bug | public | 2015-07-20 07:15 | 2018-09-14 20:23 |
| Reporter | Fat-Zer | Assigned To | eivindkvedalen | ||
| Summary | 0002195: Input validator doesn't allow comma as decimal separator inside input fields a second time | ||||
| Description | There is a minor bug in input field validator. The comma as decimal separator (DS) is not allowed to show in an expression for the second time. | ||||
| Steps To Reproduce | 1. Edit any input that allows expression e.g. a length sketch constraint. 2. Try to type in any expression with two decimals with comma DS e.g. "2,5+1,5" The validator won't allow to type in the second comma. | ||||
| Additional Information | I'm not sure if the locale should setup a comma DS to reproduce this. The dot works fine in such cases. Note: the bug was found by some german user from IRC who's nick I don't remember. | ||||
| Tags | expressions, locale, units | ||||
Until Eivind's expression parser is not merged into master there will be nothing done on this. At the moment it's just luck that you can even enter e.g. "2,5+1" because the validator doesn't explicitly forbid it. |
I will remove the target version for now as there is nobody working on it. |
fixed summary typos |
@eivindkvedalen care to weigh in on this? |
@eivindkvedalen can I assign this to you? |
An input field has an expression editor where complex expressions can be entered. There is no need that an input field should support complex expressions directly. |
| 2015-07-20 07:15 | Fat-Zer | New Issue | |
| 2015-09-15 08:57 | wmayer | Note Added: 0006424 | |
| 2015-09-15 08:57 | wmayer | Status | new => acknowledged |
| 2015-09-19 17:09 | wmayer | Relationship added | related to 0002270 |
| 2016-01-29 16:23 | yorik | Target Version | => 0.16 |
| 2016-02-12 16:14 | yorik | Note Added: 0006827 | |
| 2016-02-12 16:15 | yorik | Product Version | => 0.16 |
| 2016-02-12 16:15 | yorik | Target Version | 0.16 => |
| 2017-01-19 02:44 | Kunda1 | Note Added: 0007871 | |
| 2017-01-19 02:44 | Kunda1 | Summary | Input validator doesn't allowed comma as decimal separator inside input fiels on second time => Input validator doesn't allow comma as decimal separator inside input fields a second time |
| 2017-02-15 12:20 | Kunda1 | Tag Attached: units | |
| 2017-02-15 12:20 | Kunda1 | Tag Attached: locale | |
| 2017-02-15 12:21 | Kunda1 | Status | acknowledged => confirmed |
| 2017-02-15 12:22 | Kunda1 | Relationship added | related to 0002103 |
| 2017-05-02 11:09 | Kunda1 | Relationship added | related to 0002135 |
| 2017-10-10 02:23 | Kunda1 | Note Added: 0010278 | |
| 2017-10-10 02:24 | Kunda1 | Tag Attached: expressions | |
| 2017-12-13 15:28 | Kunda1 | Note Added: 0010600 | |
| 2017-12-13 15:29 | Kunda1 | Project | FreeCAD => Expressions |
| 2018-09-14 20:23 | wmayer | Assigned To | => eivindkvedalen |
| 2018-09-14 20:23 | wmayer | Status | confirmed => closed |
| 2018-09-14 20:23 | wmayer | Resolution | open => fixed |
| 2018-09-14 20:23 | wmayer | Fixed in Version | => 0.17 |
| 2018-09-14 20:23 | wmayer | Note Added: 0011746 |
