0002296FreeCADBugpublic2017-03-10 20:34
Reporterfreegroup Assigned Tokkremitzki
PlatformAppleOSOSXOS Version10.10.5
Product Version0.15
Summary0002296: sweep/loft on path didn't create solid
Descriptionloft a circle to a rectangle along a path (sweep) didn't create
a solid.
Steps To Reproducesee attached file
freegroup
2015-10-14 11:00
reporter
sweepTest.FCStd (Attachment missing)
freegroup
2015-10-14 11:01
reporter
Bildschirmfoto 2015-10-14 um 12.52.37.png (Attachment missing)
2017-01-23 21:37
administrator   ~0007929
OP please retest on 0.16
Also as an FYI:
1) when you post ticket in the future please add the contents of Help > About FreeCAD > Copy to clipboard
2) please write an in depth step-by-step on how to reproduce bug
Forum thread: https://forum.freecadweb.org/viewtopic.php?f=10&t=20166
normandc
2017-01-24 04:50
manager   ~0007944
The problem is that the sweep path goes underneath the position of Sketch001 (Sketch001's Z position is -50mm while the bottom end point of the arc in Sketch002 goes below at Z -55.325mm.
Raising the end of the sweep path to be at the same height as Sketch001 fixes the problem and creates a valid solid.
A developer will have to confirm, but IMO this is not a bug, but improper use of the tool.
To add to Kunda1's FYI:
0) before posting a ticket, follow the indications in the "READ THIS BEFORE REPORTING" link, which indicates such matters should be discussed over the forum first.
Tested on
OS: Ubuntu 14.04.5 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
normandc
2017-01-24 04:51
manager
sweepTest_fixed.FCStd (Attachment missing)
2017-01-31 13:22
administrator   ~0008125
No response from OP
@normandc has offered feedback and fix based on the model.
Resolving as 'no change required'
2015-10-14 11:00 freegroup New Issue
2015-10-14 11:00 freegroup File Added: sweepTest.FCStd
2015-10-14 11:01 freegroup File Added: Bildschirmfoto 2015-10-14 um 12.52.37.png
2017-01-23 21:37 Kunda1 Note Added: 0007929
2017-01-23 21:37 Kunda1 Summary sweep/loft on path didn'T create solid => sweep/loft on path didn't create solid
2017-01-23 21:38 Kunda1 Status new => feedback
2017-01-23 21:38 Kunda1 Tag Attached: #pending
2017-01-24 04:50 normandc Note Added: 0007944
2017-01-24 04:51 normandc File Added: sweepTest_fixed.FCStd
2017-01-24 04:51 normandc Note Edited: 0007944
2017-01-31 13:22 Kunda1 Note Added: 0008125
2017-01-31 13:22 Kunda1 Status feedback => resolved
2017-01-31 13:22 Kunda1 Resolution open => no change required
2017-01-31 13:22 Kunda1 Assigned To => Kunda1
2017-01-31 13:22 Kunda1 Tag Detached: #pending
2017-01-31 13:22 Kunda1 Assigned To Kunda1 =>
2017-03-10 20:34 kkremitzki Assigned To => kkremitzki
2017-03-10 20:34 kkremitzki Status resolved => closed
