| 0002299 | Sketcher | Bug | public | 2015-10-14 20:15 | 2018-09-22 16:30 |
| Target Version | 0.18 | ||||
| Summary | 0002299: Ground face of sketch for padding can be invalid | ||||
| Description | http://forum.freecadweb.org/viewtopic.php?f=13&t=12813 | ||||
Not sketch specific: https://forum.freecadweb.org/viewtopic.php?f=13&t=12813#p102562 @wmayer I have tried to reproduce this today. I see a good face when changing from 18,5 to 19 mm. OS: Ubuntu 16.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.12772 (Git) Build type: None Branch: master Hash: c8c9b76f43d2c78c4afb65b756f3f07d626aac85 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 I |
With occ 7.0 I can still confirm the issue. I don't know if you got all the details of the discussion in German. So, here are some details: When we have a sketch with several wires we have to determine what is an outer wire and what is an inner wire. A fast method is to use the diagonal of the bounding box and the wire with the longest diagonal is our outer wire. Now it's known that the bounding box occ delivers can be much bigger is it should be. This mainly happens if a shape hasn't been tessellated yet. Roman Lygin explained this behaviour in his blog. Now when changing the radius to 19mm then exactly the above situation occurs: the bounding box of the inner circle is bigger than the rounded rectangle and thus the face creation returns an invalid shape. |
@wmayer I understood the part of the bounding box. However, I have not tried to check my bounding box. I can do it if you are interested. Just tell me what to type. I have opened the sketch and changed 18.5 mm to 19 mm. I attach a picture after the change showing it is 19 mm and a face that is just preselected without the color blending you get in broken faces. Let me know if I can be further of assistance. |
Here is a modified version of the Python macro to determine the diagonal of the bounding boxes.
which returns this output:As you can see the circle has a bigger bounding box (58.167882) than the rounded rectangle (57.500704) If you have a minute then post the result of the macro after changing the radius to 19 mm and refreshing the document. |
Not in my version: |
@wmayer abdullah's results differ than yours. |
The different numbers can have two reasons: 1. Computing the bounding boxes has been improved in occ 7.1 2. He uses a different deviation value in the preferences. The lower this value, the more line segments are created and thus the more accurate the bounding box will be. I have used the default value of 0.5% |
Result: BoundBox (-20, -20, 0, 20, 20, 0): len=56.568542: 8 edges BoundBox (-17.3593, -17.3898, 0, -14.6, -14.6102, 0): len=3.916622: 1 edges BoundBox (14.6407, -17.3898, 0, 17.4, -14.6102, 0): len=3.916622: 1 edges BoundBox (-17.3593, 14.6102, 0, -14.6, 17.3898, 0): len=3.916622: 1 edges BoundBox (14.6407, 14.6102, 0, 17.4, 17.3898, 0): len=3.916622: 1 edges BoundBox (-18.3749, -18.4687, 0, 18.5, 18.4687, 0): len=52.193205: 1 edges OS: Ubuntu 16.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.13086 (Git) Build type: None Branch: master Hash: f64760b8a3dabf9d218418f6a3980d900b39d703 Python version: 2.7.12 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.1.0 Deviation: 0,0100 % If I set your deviation (0,5%), close the project, reopen the file, I get the same result: BoundBox (-20, -20, 0, 20, 20, 0): len=56.568542: 8 edges BoundBox (-17.3593, -17.3898, 0, -14.6, -14.6102, 0): len=3.916622: 1 edges BoundBox (14.6407, -17.3898, 0, 17.4, -14.6102, 0): len=3.916622: 1 edges BoundBox (-17.3593, 14.6102, 0, -14.6, 17.3898, 0): len=3.916622: 1 edges BoundBox (14.6407, 14.6102, 0, 17.4, 17.3898, 0): len=3.916622: 1 edges BoundBox (-18.3749, -18.4687, 0, 18.5, 18.4687, 0): len=52.193205: 1 edges If you need any other information, just let me know :) |
I am not able to reproduce the original issue with FC 0.17/0.18 based on OCCT 7.3.0. Besides, there are multiple redundant constraints in the sketch relating to overuse of symmetric constraints. The Sketcher in v0.18 now detects these conflicts thanks to abdullah's improvements of the solver. OS: Ubuntu 18.04.1 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.18.14498 (Git) Build type: Release Branch: master Hash: e381e6b739a6b83b5f476546b64569cfa03a4e3a Python version: 2.7.15rc1 Qt version: 4.8.7 Coin version: 4.0.0a OCC version: 7.3.0 Locale: French/Canada (fr_CA) |
@wmayer Normand can't reproduce the issue on FC 0.17/0.18 based on OCCT 7.3.0 Can you confirm? |
With OCCT 7.0 I have tested this with several tessellation tolerances and it shows the same erroneous behaviour in all cases. But since newer OCCT versions don't suffer from this issue it must be some 7.0 related. So, after all it looks like an OCCT issue which is fixed now and this means that from FreeCAD side we don't have to search for an alternative way to distinguish between outer and inner wires. |
| 2015-10-14 20:15 | wmayer | New Issue | |
| 2015-10-14 20:16 | wmayer | Project | FreeCAD => Sketcher |
| 2017-02-18 21:43 | Kunda1 | Target Version | => 0.17 |
| 2017-10-16 09:07 | wmayer | Target Version | 0.17 => |
| 2017-12-12 14:45 | abdullah | Note Added: 0010585 | |
| 2017-12-12 20:02 | wmayer | Note Added: 0010592 | |
| 2017-12-12 20:02 | wmayer | Note Edited: 0010592 | |
| 2017-12-13 13:29 | abdullah | File Added: luefterMount.png | |
| 2017-12-13 13:29 | abdullah | Note Added: 0010599 | |
| 2017-12-13 17:56 | Kunda1 | Status | new => feedback |
| 2017-12-13 18:06 | wmayer | Note Added: 0010601 | |
| 2017-12-13 18:06 | wmayer | Status | feedback => new |
| 2017-12-13 18:22 | abdullah | Note Added: 0010602 | |
| 2018-01-25 17:01 | Kunda1 | Note Added: 0010852 | |
| 2018-01-26 10:45 | wmayer | Note Added: 0010860 | |
| 2018-01-27 17:10 | abdullah | Note Added: 0010879 | |
| 2018-08-26 00:30 | Kunda1 | Target Version | => 0.18 |
| 2018-09-02 20:33 | normandc | Note Added: 0011688 | |
| 2018-09-13 14:17 | Kunda1 | Note Added: 0011728 | |
| 2018-09-13 14:17 | Kunda1 | Status | new => feedback |
| 2018-09-22 16:30 | wmayer | Assigned To | => wmayer |
| 2018-09-22 16:30 | wmayer | Status | feedback => closed |
| 2018-09-22 16:30 | wmayer | Resolution | open => won't fix |
| 2018-09-22 16:30 | wmayer | Note Added: 0011817 |
