| 0002304 | Draft | Bug | public | 2015-10-22 13:23 | 2018-12-19 21:04 |
| Reporter | jmaustpc | Assigned To | yorik | ||
| Platform | 64 bit | OS | Kubuntu | OS Version | 14.04 |
| Summary | 0002304: Duplicate multi selection of sketch element produces many sketches | ||||
| Description | Forum topic http://forum.freecadweb.org/viewtopic.php?f=10&t=12927 if you create a sketch, then with it not in edit mode, you multi select several edges and then do any of 1) Edit menu... Duplicate selection 2) Draft ...Clone 3)Part... Simple copy The result is multiple sketches. | ||||
| Additional Information | OS: Kubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.5764 (Git) Build type: Release Branch: master Hash: eff27994e57bc1eb07af8f378d1b85e3b635e194 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Tags | Clone | ||||
Confirmed in the forum |
https://github.com/FreeCAD/FreeCAD/commit/ce559a4643e5f2437d11b0063819fc462f566fb0 fixes creation of simple copies. Duplicate selection was fixed in the past. |
it's now a pure Draft issue since the bugs in core an Part module are fixed. |
DraftTools.py line 4861
Kunda edit: https://github.com/FreeCAD/FreeCAD/blob/master/src/Mod/Draft/DraftTools.py#L4861 |
@damian are you offering a fix here ? |
Yes, a fix. But there are others commands involved, like Mirror. It's possible to do a more general Draft function (consolideteSelection, for example) and apply it to every command which has the same problem PD: I don't achieve a good management of this editor Note, the indentation is terrible. |
@kkremitzki the indentation issue of 0002304:0010424 is this a result of disabling that that other plugin thing? (sorry for the vague reference) |
@Kunda1 No idea, what indentation issue exactly? |
@kkremitzki oh sorry, missed your reply. See https://freecadweb.org/tracker/bug_revision_view_page.php?bugnote_id=10424 The last line of the python code is not indented. |
This fix is now applied with https://git.io/fpX5d Currently only in Draft Clone, I'll keep this open to check other tools |
I think if several subobjects of a same object are selected, Gui.Selection.getSelection() should contain the object only once... I don't think any part of FreeCAD will expect the object to be duplicated in the list... What do you think @wmayer ? But it might be best to do this after the release, to not potentially disrupt anything |
Yes, it makes sense to avoid duplicates when only returning the document objects. |
https://github.com/FreeCAD/FreeCAD/commit/0556a2ca68e9fb171807a9c6fcb3c13939a251ef |
Thanks for the fix! |
| 2015-10-22 13:23 | jmaustpc | New Issue | |
| 2016-01-19 01:55 | yorik | Target Version | 0.16 => |
| 2017-01-28 12:16 | Kunda1 | Note Added: 0008049 | |
| 2017-01-28 12:16 | Kunda1 | Status | new => confirmed |
| 2017-01-28 12:16 | Kunda1 | Additional Information Updated | |
| 2017-05-31 04:20 | Kunda1 | Tag Attached: Clone | |
| 2017-09-15 20:32 | wmayer | Target Version | => 0.17 |
| 2017-10-01 20:13 | wmayer | Note Added: 0010230 | |
| 2017-10-18 18:48 | wmayer | Project | FreeCAD => Draft |
| 2017-10-18 18:49 | wmayer | Note Added: 0010320 | |
| 2017-11-17 22:55 | damian | Note Added: 0010424 | |
| 2017-11-18 00:53 | Kunda1 | Note Edited: 0010424 | |
| 2017-11-18 00:54 | Kunda1 | Note Edited: 0010424 | |
| 2017-11-18 00:56 | Kunda1 | Note Edited: 0010424 | |
| 2017-11-18 08:49 | Kunda1 | Note Added: 0010425 | |
| 2017-11-18 09:23 | damian | Note Edited: 0010424 | |
| 2017-11-18 09:51 | damian | Note Edited: 0010424 | |
| 2017-11-18 09:59 | damian | Note Added: 0010426 | |
| 2017-11-19 15:38 | Kunda1 | Note Added: 0010430 | |
| 2017-11-20 05:36 | kkremitzki | Note Added: 0010434 | |
| 2018-01-24 20:43 | Kunda1 | Note Added: 0010845 | |
| 2018-02-08 09:03 | wmayer | Assigned To | => yorik |
| 2018-02-08 09:03 | wmayer | Priority | normal => low |
| 2018-02-08 09:03 | wmayer | Severity | major => minor |
| 2018-02-08 09:03 | wmayer | Status | confirmed => assigned |
| 2018-02-08 09:03 | wmayer | Target Version | 0.17 => 0.18 |
| 2018-12-05 13:07 | yorik | Note Added: 0012238 | |
| 2018-12-17 14:37 | yorik | Note Added: 0012292 | |
| 2018-12-19 19:40 | wmayer | Note Added: 0012319 | |
| 2018-12-19 20:19 | wmayer | Status | assigned => closed |
| 2018-12-19 20:19 | wmayer | Resolution | open => fixed |
| 2018-12-19 20:19 | wmayer | Fixed in Version | => 0.18 |
| 2018-12-19 20:19 | wmayer | Note Added: 0012320 | |
| 2018-12-19 21:04 | yorik | Note Added: 0012322 |
