| 0002307 | PartDesign | Bug | public | 2015-10-25 22:00 | 2017-03-08 19:09 |
| Reporter | glosterva | Assigned To | kkremitzki | ||
| Platform | Dell PC i7 | OS | Windows | OS Version | 7 |
| Summary | 0002307: Polar Pattern does not work because it erroneously does not detect an intersection | ||||
| Description | I select a feature, in this case a wedge formed by two arcs and two line segments connecting them, padded to be 1 mm thick. I click on the Polar Pattern button, and it goes into the Polar Pattern editing mode. In this mode it shows the additional pieces it is supposed to create in red, and increasing or decreasing the total number appears to do what it is supposed to. I increase the total number to 8. The message at the top says "7 transformed shapes do not intersect support". (A similar message appears for all the different numbers.) There is a cylinder in the middle that the wedge *does* intersect with. I try a variety of ways of getting it to intersect, either meeting right at the edge or significantly overlapping with the cylinder. When I click OK, a Polar Pattern object is added to the model's object list on the left, but, presumably because of the error, the additional pieces do not appear. | ||||
| Steps To Reproduce | Open the file. Select Part Design. Select the wedge object (Pad001). Click the Polar Pattern button or PartDesign->PolarPattern menu item. It shows no message yet, but it is still in an error condition. Click to increase the number of occurrences and the message will appear. | ||||
| Additional Information | The PolarPattern Parameters dialog area looks nothing like the dialog shown in the documentation here: http://www.freecadweb.org/wiki/index.php?title=PartDesign_PolarPattern | ||||
| Tags | PolarPattern | ||||
Funtoo Linux. It can be reproduced by entering the part design workbench, drawing a 1mm x 1mm sketch from the origin and then generating a 1mm pad to create a 1mm cube. If the polar pattern feature is then selected and the pad is revolved through 360 degrees with 4 occurrences, the expected result should be a 2mm x 2mm x 1mm pad. However, the result is an L-shape, with the message 'One transformed shape does not intersect support'. per @thehoodedfoot in 0002307:0008364 this comment is not valid. |
Just letting you know I see this same issue here: OS: Ubuntu 15.10 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6623 (Git) Build type: None Branch: master Hash: 9d617ce4c8a0d65155c6b2d4bbff273519b6e573 Python version: 2.7.10 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
Is there a file that's supposed to be attached to this bug? |
I think I see the same problem. I have attached the 1001.{fcstd,png}. Note the warning. |
I would suggest PartDesign objects don't intersect with Part objects? In .17 version they are clearly separated, but I'm not sure about .16 |
nickoe, the error in the file you attached (1001.fcstd) is normal. Transformation tools work on PartDesign features and all the occurrences need to intersect the support. In your file, Pad (the cylinder) is not fused to the Cube, because the sketch was not mapped to a face on the Cube. Thus it is an invalid use of the tool. thehoodedfoot's cooment is a different bug entirely. Unfortunately, glosterva never provided a file, and his description is too vague to try to reproduce. IMO we should close this bug as invalid. |
@glosterva please provide a sample file to test @thehoodedfoot please open a separate bug @Sam which issue are you confirming? OP's or thehoodedfoot's? |
ping @glosterva @thehoodedfoot @Sam |
Further to the ping by Kunda1, I must state that I was incorrect in my understanding of the polar pattern feature, and that I mistakenly assumed that any intersecting features would merge. Further reading of the linear pattern documentation shows that this is not the intended or expected behaviour, and I therefore report my comment 6506 as invalid/closed. |
per @normandc advice 0002307:0007555 I'm resolving this bug as 'unable to reproduce' |
| 2015-10-25 22:00 | glosterva | New Issue | |
| 2015-10-28 13:12 | thehoodedfoot | Note Added: 0006506 | |
| 2016-03-20 18:45 | Sam | Note Added: 0006918 | |
| 2016-05-10 00:42 | ezzieyguywuf | Note Added: 0007075 | |
| 2016-12-01 19:59 | nickoe | File Added: 1001.png | |
| 2016-12-01 19:59 | nickoe | File Added: 1001.fcstd | |
| 2016-12-01 20:00 | nickoe | Note Added: 0007502 | |
| 2016-12-02 16:26 | poserge | Note Added: 0007506 | |
| 2016-12-29 00:05 | normandc | Note Added: 0007555 | |
| 2017-01-11 22:57 | Kunda1 | Note Added: 0007660 | |
| 2017-01-11 22:57 | Kunda1 | Status | new => feedback |
| 2017-01-29 14:56 | Kunda1 | Tag Attached: split ticket | |
| 2017-02-18 12:20 | Kunda1 | Note Added: 0008347 | |
| 2017-02-18 12:20 | Kunda1 | Note Edited: 0008347 | |
| 2017-02-19 10:38 | thehoodedfoot | Note Added: 0008364 | |
| 2017-02-19 14:05 | Kunda1 | Note Edited: 0006506 | |
| 2017-02-19 14:06 | Kunda1 | Tag Detached: split ticket | |
| 2017-02-19 14:06 | Kunda1 | Tag Attached: PolarPattern | |
| 2017-02-19 14:06 | Kunda1 | Tag Attached: #pending | |
| 2017-02-19 14:10 | Kunda1 | Status | feedback => resolved |
| 2017-02-19 14:10 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-02-19 14:10 | Kunda1 | Note Added: 0008366 | |
| 2017-02-19 14:10 | Kunda1 | Tag Detached: #pending | |
| 2017-03-08 19:09 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-08 19:09 | kkremitzki | Status | resolved => closed |
