| 0002323 | FreeCAD | Bug | public | 2015-11-01 09:53 | 2018-08-26 15:23 |
| Reporter | lanciaux | Assigned To | yorik | ||
| Summary | 0002323: Workbench Start recent list of 3 files is - after a crash - not sync with recent list in File Menu Recent list of 4 files | ||||
| Description | There is an index of 1 file shifted - you choose top first one on Start Workbench and got another one that was earlier of that position of list. | ||||
Hello, a good pic is worth a thousand words. If you choose "LIGNESDEVIE_V2015.fcstd" on right ... you will get "vaBWB_HallFlux3D_V5.fcstd" on left. |
Probably the RecentFiles parameters were not written correctly when the crash occured. In case this happens again (to you or anyone else coming here), could you: - Open FreeCAD - menu Tools -> Edit Parameters - Check the contents of BaseApp -> Preferences -> RecentFiles - Compare with the contents of menu File -> Recent Files - Compare with the contents of the start page |
Forum thread: https://forum.freecad.org/viewtopic.php?f=10&t=20098 |
@chrisb writes in https://forum.freecad.org/viewtopic.php?f=10&t=20098&p=156785#p154919 > Has this to do with the problem that the filelist on the start page is not rewritten after opening a file? If I open a new file, close it and select one from the start page I get the wrong file. |
> Has this to do with the problem that the filelist on the start page is not rewritten after opening a file? If I open a new file, close it and select one from the start page I get the wrong file. Not happening for me... Saving a file then reopening it shows the correct file in both the File menu and on the start page |
@chrisb can still reproduce on: OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.11174 (Git) Build type: None Branch: master Hash: 0e9c1c076e311f2c3903cfa9de87c8c88daa79de Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 7.1.0 |
https://github.com/FreeCAD/FreeCAD/commit/74b7373e48b3799d2cd3784ebc131f4f6373e637 |
| 2015-11-01 09:53 | lanciaux | New Issue | |
| 2015-11-16 21:26 | lanciaux | File Added: FreeCAD_RecentlyOpenedFiles_Bugs.png | |
| 2015-11-16 21:28 | lanciaux | Note Added: 0006546 | |
| 2016-02-28 22:43 | yorik | Note Added: 0006861 | |
| 2016-02-28 22:43 | yorik | Assigned To | => yorik |
| 2016-02-28 22:43 | yorik | Status | new => feedback |
| 2017-01-21 13:30 | Kunda1 | Note Added: 0007904 | |
| 2017-01-29 15:06 | Kunda1 | Note Added: 0008077 | |
| 2017-01-29 15:07 | Kunda1 | Tag Attached: #pending | |
| 2017-01-30 15:38 | yorik | Note Added: 0008107 | |
| 2017-03-17 22:37 | Kunda1 | Tag Attached: #lowhangingfruit | |
| 2017-05-31 00:37 | Kunda1 | Note Added: 0009207 | |
| 2017-05-31 00:37 | Kunda1 | Status | feedback => confirmed |
| 2017-05-31 00:37 | Kunda1 | Product Version | => 0.17 |
| 2017-05-31 00:39 | Kunda1 | Status | confirmed => assigned |
| 2017-05-31 14:10 | Kunda1 | Note Added: 0009222 | |
| 2017-05-31 14:11 | Kunda1 | Note Edited: 0009222 | |
| 2017-05-31 14:11 | Kunda1 | Target Version | => 0.17 |
| 2017-10-05 08:40 | wmayer | Status | assigned => closed |
| 2017-10-05 08:40 | wmayer | Resolution | open => fixed |
| 2017-10-05 08:40 | wmayer | Fixed in Version | => 0.17 |
| 2017-10-05 08:40 | wmayer | Note Added: 0010247 | |
| 2018-08-26 15:23 | Kunda1 | Tag Detached: #lowhangingfruit | |
| 2018-08-26 15:23 | Kunda1 | Tag Detached: #pending |
