0002324FreeCADBugpublic2017-01-31 14:19
Reporterlanciaux Assigned To
Summary0002324: PDF export behavior difference between Main Screen and Drawing Page rendering (under virtualbox only)
DescriptionI'm using VirtualBOX under Windows 7 to work with an OpenSUSE 13.x Linux ... for FreeCAD. Only when running VBox that has issues with the OpenGL driver, I met this weird difference :
- If I want to do a Print/Print Preview/Print Image/PDF export of main screen from main menus ... I got an empty file or a file with only a few bytes and correctly closed.
- If I do a Print/Print Preview/PDF export from the Drawing Workbench screen (it means a Page has been rendered), I got right file, not empty.
Most of my export in VBox are PDF output from Drawing Workbench but sometimes I have to take screen snapshot, so I use KSnapshot to do.
If you correct it, please make extending good Drawing behavior to Main Screen behavior and not adverse.
Thanks
Ludovic
2017-01-17 05:58
administrator   ~0007834
Can you reproduce on latest stable?
Also please post your Help > About FreeCAD > copy to clipboard
2017-01-29 15:04
administrator   ~0008076
Resolving due to lack of response from OP
2017-01-31 14:19
administrator   ~0008128
It's known that the graphic drivers provided by virtual box are rather poor -- especially pbuffers don't work well/at all.
An alternative is to use framebuffer object which can be forced by this parameter:
in the parameter editor go to User parameter:BaseApp/Preferences/Document and create the boolean key DisablePBuffers and set it to true.
2015-11-01 14:35 lanciaux New Issue
2017-01-17 05:58 Kunda1 Note Added: 0007834
2017-01-17 05:58 Kunda1 Status new => feedback
2017-01-29 15:04 Kunda1 Note Added: 0008076
2017-01-29 15:04 Kunda1 Status feedback => resolved
2017-01-29 15:04 Kunda1 Resolution open => no change required
2017-01-29 15:04 Kunda1 Assigned To => Kunda1
2017-01-29 15:04 Kunda1 Assigned To Kunda1 =>
2017-01-31 14:19 wmayer Note Added: 0008128
2017-01-31 14:19 wmayer Status resolved => closed
