| 0002352 | FreeCAD | Bug | public | 2015-12-02 14:01 | 2019-08-14 12:22 |
| Reporter | saso | Assigned To | eivindkvedalen | ||
| Summary | 0002352: Spreadsheet bugs | ||||
| Description | as reported here http://forum.freecadweb.org/viewtopic.php?f=3&t=13287&start=20#p107102 | ||||
| Steps To Reproduce | If we add something like this (first number is just to show the cell, so first cell A1 just has the value "20", the exact numbers are not important) Case #1 A1 "20" A2 "15" A3 "16" A4 "25" A5 "=sum(A1:A4)" Removing a row from A1 to A3 works OK, removing row A4, last row before the sum, gives unexpected result, broken formula/function... Case 0000002 A1 "20" A2 "15" A3 "16" A4 "25" A5 "=sum(A1:A4)" A6 "=A5/2" Removing any row from A1 to A4 will give this error (this is the case with the more recent dev builds, older builds also had this bug but I believe there was no error reported) Exception (Tue Dec 01 17:13:02 2015): Invalid column specification Unhandled Base::Exception caught in GUIApplication::notify. The error message is: FreeCAD exception thrown (Invalid column specification) | ||||
Could you please try https://github.com/eivindkv/free-cad-code/commits/Spreadsheet_fixes_20151203 It's rebased on recent master. |
Sorry but at the moment I don't have a build environment set up so that I could test this. I trust your code :) but if you think it would be good to test we can ask in the forum... |
I can't confirm this behaviour neither on Windows (Debug/Release) nor on Ubuntu. EDIT: Now I can see it, too. Tested with: OS: Windows 7 Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6018 (Git) Build type: Release Branch: master Hash: c67b2bed45ac8b7bf6f7eda3c22541a26fce571a Python version: 2.7.6 Qt version: 4.8.5 Coin version: 4.0.0a OCC version: 6.6.0 ----------------------------------------------- OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6018 (Git) Build type: Release Branch: master Hash: c67b2bed45ac8b7bf6f7eda3c22541a26fce571a Python version: 2.7.3 Qt version: 4.8.1 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.17 |
FreeCAD: master 4b5ae54e 2015-12-03 21:36:21 Eivind Kvedalen Committer: wmayer Details Diff |
App: Removed VariableExpression::setName(), and replace call by setPath(); it's use caused a crash (0002352). |
Affected Issues 0002352 |
| mod - src/App/Expression.h | Diff File | ||
| mod - src/Mod/Spreadsheet/App/PropertySheet.cpp | Diff File | ||
FreeCAD: master 71605e63 2015-12-03 21:39:11 Eivind Kvedalen Committer: wmayer Details Diff |
Spreadsheet: Fixed issue 0002352, removal of rows and columns. |
| 2015-12-02 14:01 | saso | New Issue | |
| 2015-12-03 19:35 | eivindkvedalen | Assigned To | => eivindkvedalen |
| 2015-12-03 19:35 | eivindkvedalen | Status | new => assigned |
| 2015-12-03 20:55 | eivindkvedalen | Note Added: 0006579 | |
| 2015-12-04 19:24 | saso | Note Added: 0006580 | |
| 2015-12-09 11:00 | wmayer | Note Added: 0006582 | |
| 2015-12-09 11:11 | wmayer | Note Edited: 0006582 | |
| 2015-12-09 11:47 | wmayer | Changeset attached | => FreeCAD Master master 71605e63 |
| 2015-12-09 11:49 | wmayer | Status | assigned => closed |
| 2015-12-09 11:49 | wmayer | Resolution | open => fixed |
| 2015-12-09 11:49 | wmayer | Fixed in Version | => 0.16 |
| 2019-08-14 12:22 | Kunda1 | Changeset attached | => FreeCAD master 4b5ae54e |
