| 0002359 | File formats | General | public | 2015-12-10 16:10 | 2017-05-05 22:26 |
| Reporter | l3iggs | Assigned To | keithsloan52 | ||
| Platform | Linux | OS | Arch Linux | ||
| Summary | 0002359: OpenSCAD import is broken by lack of support for hull() function | ||||
| Description | OpenSCAD has a function called hull(): https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Transformations#hull A simple example .scad file using this is: hull() { translate([15,10,0]) circle(10); circle(10); } This translates the following .csg content: group() { hull() { multmatrix([[1, 0, 0, 15], [0, 1, 0, 10], [0, 0, 1, 0], [0, 0, 0, 1]]) { circle($fn = 0, $fa = 12, $fs = 2, r = 10); } circle($fn = 0, $fa = 12, $fs = 2, r = 10); } } When opening/importing either of these, FreeCAD enters some sort of endless loop of death while trying to process the input. | ||||
| Steps To Reproduce | open hullTest.scad (attached) | ||||
| Additional Information | Please notify Keith Sloan <keith@sloan-home.co.uk> and Sebastian Hoogen <sebastian@hoogen.de>, Sebastian Hoogen <sebastian@sebastianhoogen.de> | ||||
| Tags | OpenSCAD | ||||
| related to | 0002360 | closed | keithsloan52 | OpenSCAD import is broken by lack of support for the offset() function |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19860 |
Confirmed. I open the attached file in OpenSCAD, export to .csg, open in FreeCAD, and get an error:
End processing CSG file
processing circle
successfully exported /tmp/fc-31164-114818-000004.dxf
processing circle001
successfully exported /tmp/fc-31164-114818-000005.dxf
File "/usr/lib/freecad-daily/Mod/OpenSCAD/OpenSCADFeatures.py", line 455, in execute
fp.Operation, maxmeshpoints=maxmeshpoints)
File "/usr/lib/freecad-daily/Mod/OpenSCAD/OpenSCADUtils.py", line 548, in process_ObjectsViaOpenSCADShape
return process2D_ObjectsViaOpenSCADShape(children,name,doc)
File "/usr/lib/freecad-daily/Mod/OpenSCAD/OpenSCADUtils.py", line 488, in process2D_ObjectsViaOpenSCADShape
tmpfilename = callopenscadstring('%s(){%s}' % (Operation,dxfimports),'dxf')
File "/usr/lib/freecad-daily/Mod/OpenSCAD/OpenSCADUtils.py", line 177, in callopenscadstring
keepname=True)
File "/usr/lib/freecad-daily/Mod/OpenSCAD/OpenSCADUtils.py", line 164, in callopenscad
raise OpenSCADError('OpenSCAD executeable unavailable')
<class 'OpenSCADUtils.OpenSCADError'>: 'OpenSCAD executeable unavailable'
In spite of the error message I do have the OpenSCAD executable. |
Works just fine for me. Maybe kkremitzki has a permissions problem on his/her openscad executable. There was a fix for hull and 2d objects at https://forum.freecadweb.org/viewtopic.php?f=27&t=18233&p=142918#p142918 |
@kkremitzki ping |
Resolving unless @kkremitzki needs to reopen. |
@kkremitzki can we also make keithsloan52 a developer so we can attribute fixes to him? |
@Kunda1 done |
Closing |
| 2015-12-10 16:10 | l3iggs | New Issue | |
| 2015-12-10 16:10 | l3iggs | File Added: hullTest.scad | |
| 2017-01-13 20:47 | Kunda1 | Note Added: 0007729 | |
| 2017-01-16 18:48 | Kunda1 | Project | FreeCAD => File formats |
| 2017-01-16 18:48 | Kunda1 | Category | Bug => General |
| 2017-01-27 03:30 | Kunda1 | Relationship added | related to 0002360 |
| 2017-02-15 06:48 | kkremitzki | Note Added: 0008306 | |
| 2017-02-15 06:48 | kkremitzki | Status | new => confirmed |
| 2017-04-25 19:36 | keithsloan52 | File Added: hullTest.fcstd | |
| 2017-04-25 19:36 | keithsloan52 | Note Added: 0008759 | |
| 2017-04-25 23:39 | Kunda1 | Note Added: 0008760 | |
| 2017-04-28 12:24 | Kunda1 | Status | confirmed => resolved |
| 2017-04-28 12:24 | Kunda1 | Resolution | open => fixed |
| 2017-04-28 12:24 | Kunda1 | Note Added: 0008797 | |
| 2017-05-02 14:48 | Kunda1 | Note Added: 0008856 | |
| 2017-05-02 14:49 | Kunda1 | Note Edited: 0008856 | |
| 2017-05-03 17:25 | kkremitzki | Note Added: 0008881 | |
| 2017-05-03 19:22 | Kunda1 | Assigned To | => keithsloan52 |
| 2017-05-04 10:39 | Kunda1 | Tag Attached: OpenSCAD | |
| 2017-05-05 22:26 | Kunda1 | Status | resolved => closed |
| 2017-05-05 22:26 | Kunda1 | Note Added: 0008893 |
