| 0002372 | FreeCAD | Bug | public | 2015-12-18 09:06 | 2016-01-19 02:06 |
| Reporter | ChapaikinVA | Assigned To | wmayer | ||
| Platform | Linux | OS | Ubuntu | OS Version | 14.04 x64 |
| Summary | 0002372: Application terminates on attempt to change external geometry from a sketch | ||||
| Description | (Sketcher) Application terminates on attempt to set a constraint "Height" for a line from an external geometry. | ||||
| Steps To Reproduce | 1. Open "Sketch" 2. Select "3-Line" 3. Set a constraint "Vertical distance" / "Height" (default: Shift+V) | ||||
| Additional Information | OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6062 (Git) Build type: None Branch: master Hash: 61e1a5ca2fee4ea7a95965afdbb510a450d46660 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Cannot confirm this behaviour on Ubuntu 12.04 but it crashes on Windows 64-bit (debug mode). Might be related to the used Eigen3 version. On Ubuntu it's 3.0.5 and on Windows it's 3.2.5. The callstack is this: msvcr90d.dll!_wassert(const wchar_t * expr=0x000007feda2628c0, const wchar_t * filename=0x000007feda262810, unsigned int lineno=19) Line 337 C > Sketcher_d.pyd!Eigen::SparseMatrixBase<Eigen::CwiseUnaryOp<Eigen::internal::scalar_abs2_op<double>,Eigen::Block<Eigen::SparseMatrix<double,0,int>,-1,1,1> const > >::sum() Line 19 + 0x48 bytes C++ Sketcher_d.pyd!Eigen::SparseMatrixBase<Eigen::Block<Eigen::SparseMatrix<double,0,int>,-1,1,1> >::squaredNorm() Line 82 + 0x1b bytes C++ Sketcher_d.pyd!Eigen::SparseMatrixBase<Eigen::Block<Eigen::SparseMatrix<double,0,int>,-1,1,1> >::norm() Line 90 + 0xa bytes C++ Sketcher_d.pyd!Eigen::SparseQR<Eigen::SparseMatrix<double,0,int>,Eigen::COLAMDOrdering<int> >::factorize(const Eigen::SparseMatrix<double,0,int> & mat={...}) Line 378 + 0x54 bytes C++ Sketcher_d.pyd!Eigen::SparseQR<Eigen::SparseMatrix<double,0,int>,Eigen::COLAMDOrdering<int> >::compute(const Eigen::SparseMatrix<double,0,int> & mat={...}) Line 102 C++ Sketcher_d.pyd!Eigen::SparseQR<Eigen::SparseMatrix<double,0,int>,Eigen::COLAMDOrdering<int> >::SparseQR<Eigen::SparseMatrix<double,0,int>,Eigen::COLAMDOrdering<int> >(const Eigen::SparseMatrix<double,0,int> & mat={...}) Line 89 + 0xf bytes C++ Sketcher_d.pyd!GCS::System::diagnose(GCS::Algorithm alg=DogLeg) Line 3446 + 0x50 bytes C++ Sketcher_d.pyd!GCS::System::initSolution(GCS::Algorithm alg=DogLeg) Line 949 C++ Sketcher_d.pyd!Sketcher::Sketch::setUpSketch(const std::vector<Part::Geometry *,std::allocator<Part::Geometry *> > & GeoList=[3](0x00000000091e05d0 {myCurve={...} },0x0000000009250fd0 {myCurve={...} },0x00000000090fc740 {myCurve={...} }), const std::vector<Sketcher::Constraint *,std::allocator<Sketcher::Constraint *> > & ConstraintList=[1](0x00000000090398f0 {Value=10.000000000000000 Type=DistanceY AlignmentType=Undef ...}), int extGeoCount=3) Line 138 C++ Sketcher_d.pyd!Sketcher::SketchObject::solve(bool updateGeoAfterSolving=true) Line 204 + 0x75 bytes C++ Sketcher_d.pyd!Sketcher::SketchObjectPy::addConstraint(_object * args=0x0000000003f54e90) Line 271 C++ The assert where is fails prints the message: "you are using a non initialized matrix". When trying this on older versions 0.13, 0.14 or 0.15 an error dialog comes up explaining that it's not possible to set a vertical (length) constraint on an external geometry. In 0.16 this dialog doesn't come up any more and I wonder why. So, it's clearly a regression independent of the used Eigen version. |
This is the link of the changes that introduced non-driving constraints. This means it's intended behaviour to allow to add constraints to external geometries. https://github.com/FreeCAD/FreeCAD/commit/bc85670ce955e0cfaa0aecce848017be1d4db10a#diff-c4b9037af907a0a4082031a362f281c4L1271 So, it falls back to Eigen and we have to determine if the matrix is valid before applying Eigen stuff on it. |
For testing purposes I switched back to Eigen 3.0.5 on Windows and now it works. So, it's definitely related to the used version of Eigen. This means we have to a workaround for this... |
When debugging through then inside System::diagnose we have "clist" with a single element and an empty "plist". So, this means we get a 1 x 0 matrix which doesn't make sense. (Btw, when just adding an external constraint the matrix is a 0 x 0 matrix.) Now, with Eigen3.0.5 it doesn't crash because it executes the path of the dense matrix handling while Eigen3.2.x is goes the path of the sparse matrix handling. So, it's a bug in FreeCAD and the function System::diagnose must return immediately when clist or plist is empty. |
FreeCAD: master 632eaead 2015-12-25 09:47:25 Details Diff |
+ fixes 0002372: Application terminates on attempt to change external geometry from a sketch + fixes 0002373: When Measuring in the distance between two external geometry Freecad crashes |
Affected Issues 0002372, 0002373 |
| mod - src/Mod/Sketcher/App/planegcs/GCS.cpp | Diff File | ||
| 2015-12-18 09:06 | ChapaikinVA | New Issue | |
| 2015-12-18 09:06 | ChapaikinVA | File Added: Bug_external_2015-12-18 14:55:03.fcstd | |
| 2015-12-20 23:13 | yorik | Relationship added | related to 0002373 |
| 2015-12-24 15:14 | wmayer | Note Added: 0006630 | |
| 2015-12-24 15:14 | wmayer | Assigned To | => abdullah |
| 2015-12-24 15:14 | wmayer | Status | new => assigned |
| 2015-12-24 15:34 | wmayer | Note Added: 0006631 | |
| 2015-12-24 15:49 | wmayer | Relationship replaced | has duplicate 0002373 |
| 2015-12-24 16:02 | wmayer | Note Added: 0006633 | |
| 2015-12-24 16:44 | wmayer | Note Added: 0006634 | |
| 2015-12-25 09:38 | wmayer | Changeset attached | => FreeCAD Master master 632eaead |
| 2015-12-25 09:38 | wmayer | Assigned To | abdullah => wmayer |
| 2015-12-25 09:38 | wmayer | Status | assigned => closed |
| 2015-12-25 09:38 | wmayer | Resolution | open => fixed |
