| 0002373 | FreeCAD | Bug | public | 2015-12-19 13:21 | 2016-01-19 02:06 |
| Reporter | nmac2011 | Assigned To | wmayer | ||
| Platform | Ubuntu | OS | Trusty Tar | OS Version | 14.04 |
| Summary | 0002373: When Measuring in the distance between two external geometry Freecad crashes | ||||
| Description | While I don't really see any reason why one would want to do this I feel as though it definitely should not cause the the program to crash and close. OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6061 (Git) Build type: None Branch: master Hash: f958dadb698f83d6ce450cf4a9decb3515740c4c Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
| Steps To Reproduce | 1. Create a sketch in part design 2. Pad the sketch 3. Create a new sketch on the one of the faces of the pad 4. select 2 external geometries 5. Put a constraint length constraint between them Program Crashes An error message like can not put length constraints between external geometries would be nice. | ||||
The same is desribed in: /view.php?id=2372 |
Since v0.16 "non-driving" constraints have been added which allows to also add constraints to external geometries. This can be useful to e.g. measure distances or angles and so on. Now it seems that with a newer Eigen version something has been broken. Ubuntu 14.04 uses Eigen 3.2.0 while Ubuntu uses 3.0.5 and there no crash happens. On Windows I have Eigen 3.2.5 and there I get a crash too. |
FreeCAD: master 632eaead 2015-12-25 09:47:25 Details Diff |
+ fixes 0002372: Application terminates on attempt to change external geometry from a sketch + fixes 0002373: When Measuring in the distance between two external geometry Freecad crashes |
Affected Issues 0002372, 0002373 |
| mod - src/Mod/Sketcher/App/planegcs/GCS.cpp | Diff File | ||
| 2015-12-19 13:21 | nmac2011 | New Issue | |
| 2015-12-19 16:05 | ChapaikinVA | Note Added: 0006619 | |
| 2015-12-20 23:13 | yorik | Relationship added | related to 0002372 |
| 2015-12-24 15:45 | wmayer | Note Added: 0006632 | |
| 2015-12-24 15:49 | wmayer | Relationship replaced | duplicate of 0002372 |
| 2015-12-24 15:49 | wmayer | Assigned To | => abdullah |
| 2015-12-24 15:49 | wmayer | Status | new => assigned |
| 2015-12-25 09:38 | wmayer | Changeset attached | => FreeCAD Master master 632eaead |
| 2015-12-25 09:38 | wmayer | Assigned To | abdullah => wmayer |
| 2015-12-25 09:38 | wmayer | Status | assigned => closed |
| 2015-12-25 09:38 | wmayer | Resolution | open => fixed |
