| 0002386 | FreeCAD | Bug | public | 2016-01-01 16:09 | 2018-08-26 15:23 |
| Reporter | tanderson69 | Assigned To | |||
| Platform | amd64 | OS | Kubuntu | OS Version | 14.10 |
| Summary | 0002386: refine cylindrical faces corrupts solid | ||||
| Description | run attached model through refine shape and faces are remove turning solid into open shell. | ||||
| Additional Information | In the attached file: there are the faces that are trying to be joined, the front and back 'encircling' wires, the output face, and the original freecad model. | ||||
Reminder sent to: jrheinlaender @jrheinlaender checking status on 0002386 Do you still want this ticket assigned to you? |
not really - I'm too busy with another programming task and also currently not using FreeCAD at all |
Unassigned @jrheinlaender Setting to 'Confirmed' status |
@tanderson69 can you start a forum thread to discuss this issue then the thread <=> ticket bidirectionally ? Thanks! |
Added forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=21109 |
https://forum.freecadweb.org/viewtopic.php?f=8&t=21109#p178199 |
| 2016-01-01 16:09 | tanderson69 | New Issue | |
| 2016-01-01 16:09 | tanderson69 | Status | new => assigned |
| 2016-01-01 16:09 | tanderson69 | Assigned To | => jrheinlaender |
| 2016-01-01 16:09 | tanderson69 | File Added: refineCylinderBug.tar.gz | |
| 2017-02-15 04:45 | Kunda1 | Note Added: 0008302 | |
| 2017-02-15 04:45 | Kunda1 | Tag Attached: #pending | |
| 2017-02-15 17:49 | jrheinlaender | Note Added: 0008309 | |
| 2017-02-15 18:35 | Kunda1 | Note Added: 0008310 | |
| 2017-02-15 18:35 | Kunda1 | Assigned To | jrheinlaender => |
| 2017-02-15 18:35 | Kunda1 | Status | assigned => confirmed |
| 2017-02-15 18:37 | Kunda1 | Note Added: 0008311 | |
| 2017-02-15 18:37 | Kunda1 | Status | confirmed => feedback |
| 2017-03-05 18:36 | Kunda1 | Note Added: 0008543 | |
| 2017-06-15 16:39 | Kunda1 | Status | feedback => confirmed |
| 2017-09-24 22:30 | wmayer | Status | confirmed => closed |
| 2017-09-24 22:30 | wmayer | Resolution | open => unable to reproduce |
| 2017-09-24 22:30 | wmayer | Note Added: 0010180 | |
| 2018-08-26 15:23 | Kunda1 | Tag Detached: #pending |
