| 0002399 | FreeCAD | Bug | public | 2016-01-09 18:21 | 2017-02-07 13:40 |
| Reporter | ChapaikinVA | Assigned To | |||
| Summary | 0002399: Scaling breaks a shape's geometry | ||||
| Description | After scaling a Clone the geometry checker finds geometry errors. | ||||
| Steps To Reproduce | 1. Select "Clone of Common007" 2. Set scale Y=1,001 3. Click the toolbutton "Check Geometry" (!) There are some errors are found! 4. Set scale Y=1,000 5. Check the geometry again. (???) No errors found! | ||||
| Additional Information | OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6188 (Git) Build type: None Branch: master Hash: bf19e80de17454b170cde98df5e4995a7a4991f6 Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
I mean "Scaling breaks", not "Scaling brakes". Sorry. |
Please discuss issues you find in the Help forums before creating bug tickets. Your file way more complex than needed to see this issue. Scaling a Draft Clone of a default Part Cylinder, in Y from default 1.00 to 1.01 and then running a Part Check Geometry shows errors in the two FreeCADs I tried it in. I have added a very simple file containing the above.... scaleofCloneofPartCylindergetserrors.fcstd If you run Part Check Geometry on Clone, it will show errors. OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6205 (Git) Build type: Debug Branch: master Hash: 89cb2479232ea949b368e849d90fd6ce563154c1 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.8.0.oce-0.18-dev and OS: Ubuntu 12.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6245 (Git) Build type: Debug Branch: master Hash: ebc6d37262f1b07358351e336fa480f135baa240 Python version: 2.7.3 Qt version: 4.8.2 Coin version: 3.1.3 OCC version: 6.9.1.oce-0.18-dev |
I get no errors, if I do the same as my last post except with a default Part Cube. |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19977 |
looks like workflow not software error per jmaustpc's example. No response from OP. Resolving as 'no change required'. |
| 2016-01-09 18:21 | ChapaikinVA | New Issue | |
| 2016-01-09 18:21 | ChapaikinVA | File Added: bug_Scaling-brakes-geometry.2016-01-09 23:51:57.fcstd | |
| 2016-01-09 18:23 | ChapaikinVA | File Added: system.cfg | |
| 2016-01-09 18:23 | ChapaikinVA | File Added: user.cfg | |
| 2016-01-09 18:29 | ChapaikinVA | Note Added: 0006700 | |
| 2016-01-21 17:09 | jmaustpc | Note Added: 0006749 | |
| 2016-01-21 17:10 | jmaustpc | File Added: scaleofCloneofPartCylindergetserrors.fcstd | |
| 2016-01-21 17:11 | jmaustpc | Note Edited: 0006749 | |
| 2016-01-21 17:14 | jmaustpc | Note Added: 0006750 | |
| 2017-01-17 16:45 | Kunda1 | Summary | Scaling brakes a shape's geometry => Scaling breaks a shape's geometry |
| 2017-01-17 16:47 | Kunda1 | Note Added: 0007839 | |
| 2017-02-07 02:40 | Kunda1 | Note Added: 0008229 | |
| 2017-02-07 02:40 | Kunda1 | Status | new => resolved |
| 2017-02-07 02:40 | Kunda1 | Resolution | open => no change required |
| 2017-02-07 02:40 | Kunda1 | Assigned To | => Kunda1 |
| 2017-02-07 02:40 | Kunda1 | Assigned To | Kunda1 => |
| 2017-02-07 13:40 | wmayer | Status | resolved => closed |
