| 0002404 | FreeCAD | Bug | public | 2016-01-11 22:12 | 2017-03-10 20:34 |
| Reporter | LUCINIKI | Assigned To | kkremitzki | ||
| Platform | PC | OS | Windows 64 | OS Version | 10 |
| Summary | 0002404: different behaviors between the 32- and 64-bit | ||||
| Description | un progetto vari pezzi disegnati e assemblati con la versione 0.15 a 32 bit, se viene aperto dalla stessa versione ma a 64 bit e si vuole riordinare i componenti assemblati, succede che i vincoli non combaciano e non è più possibile ripristinarli. | ||||
| Steps To Reproduce | in a project with many pieces designed and assembled with the 32-bit version, if you open the 64-bit version and you want to rearrange the components assembled, it happens that the bonds do not fit and you can not restore them. | ||||
| Additional Information | the Windows version of the 32-bit pc is XP | ||||
Can you please attach a file that shows the problem? |
Not sure why but here is another example of how mantis will not switch the 'Feedback' status back to 'New' when OP replies to feedback status. Bumping https://forum.freecadweb.org/viewtopic.php?f=3&t=13619&p=154875#p154875 |
Per @sgrogan in https://forum.freecadweb.org/viewtopic.php?f=3&t=13619&start=50#p157161 |
| 2016-01-11 22:12 | LUCINIKI | New Issue | |
| 2016-01-11 23:49 | yorik | Note Added: 0006711 | |
| 2016-01-11 23:49 | yorik | Status | new => feedback |
| 2016-01-25 21:23 | LUCINIKI | File Added: nastro a cinghie_creato_x86.FCStd | |
| 2016-01-25 21:23 | LUCINIKI | File Added: nastro a cinghie_aperto_64.FCStd | |
| 2017-01-21 13:40 | Kunda1 | Note Added: 0007905 | |
| 2017-01-21 13:40 | Kunda1 | Status | feedback => new |
| 2017-01-31 17:50 | Kunda1 | Note Added: 0008130 | |
| 2017-01-31 17:50 | Kunda1 | Status | new => resolved |
| 2017-01-31 17:50 | Kunda1 | Resolution | open => no change required |
| 2017-01-31 17:50 | Kunda1 | Assigned To | => Kunda1 |
| 2017-01-31 17:50 | Kunda1 | Assigned To | Kunda1 => |
| 2017-03-10 20:34 | kkremitzki | Assigned To | => kkremitzki |
| 2017-03-10 20:34 | kkremitzki | Status | resolved => closed |
