0002409FreeCADBugpublic2017-01-15 02:20
ReporterKhazAkar Assigned Tojmaustpc
PriorityurgentSeveritycrashReproducibilityalways
PlatformPC/NotebookOSLinuxOS VersionSiduction
Product Version0.15
Summary0002409: 0.15 and 0.16 from ubuntu ppa - crash,when using Part module
DescriptionI want to use Part module,e.x to cut a hole with cylinder on sphere. When firstly click Sphere,then Cylinder and click to cut - In Xterm shows "SIGSEGV Raise". When I want to do again - crash. When want to do cut sphere in Cylinder = rapid crash.
It's hardware-independed - PC with GTX760 and Notebook with Quadro NVS 160M crash the same.
It's not driver-related,because on PC I have Nouveau,and on Notebook - blob.
Additional info(from GDB,notebook):
http://wklej.org/id/1907976/
http://wklej.org/id/1907979/
It's 0.16 version. 0.15 do the same,on PC the same too.
Steps To Reproduce1. Launch FreeCAD
2. New file
3. Take Part workbench
4. Make Cylinder
5. Make Sphere
6. Select Cylinder and Sphere
7. Click to cut/fuse(do the same effect - crash)
Additional InformationNotebook - Dell E6500
Tagscrash, linux
yorik
2016-01-17 14:39
administrator   ~0006725
This is a known bug... You need to install OCE 0.17 from the same PPA.
KhazAkar
2016-01-17 15:48
reporter   ~0006726
I have installed OCE from the same PPA and It's still crashing.
KhazAkar
2016-01-17 16:04
reporter   ~0006727
What's more - after try to reinstall FreeCAD I cannot install it,because It want libcoin80,libshiboken1.2 and libzipbios++0c2a,which my Debian unstable-based Siduction distro don't have it.
yorik
2016-01-17 21:47
administrator   ~0006728
Are you sure it's OCE from the PPA? It should be 0.17, not 0.15. This bug is caused by OCE 0.15.
If you try to use a PPA with a debian-based system, it is very likely to give problems, this is not FreeCAD's fault :)
jmaustpc
2016-01-20 14:57
manager   ~0006738
Thank you for spending the time to create this ticket but this would have been better to have discussed on the Help forum, its not a FreeCAD bug, its user error. The PPA is for Ubuntu and its derivatives, not Debian or others.
Its almost always best to discuss a potential bug in the forums before you create a bug ticket where more eyes can see it, so that we keep bug tickets quality high and reduce unneeded tickets.
2016-01-16 19:26 KhazAkar New Issue
2016-01-16 19:26 KhazAkar Tag Attached: crash
2016-01-16 19:26 KhazAkar Tag Attached: freecad
2016-01-16 19:26 KhazAkar Tag Attached: linux
2016-01-16 19:26 KhazAkar Tag Attached: SIGSEGV
2016-01-16 19:26 KhazAkar Tag Detached: freecad
2016-01-17 14:39 yorik Note Added: 0006725
2016-01-17 15:48 KhazAkar Note Added: 0006726
2016-01-17 16:04 KhazAkar Note Added: 0006727
2016-01-17 21:47 yorik Note Added: 0006728
2016-01-20 14:57 jmaustpc Note Added: 0006738
2016-01-20 14:57 jmaustpc Status new => closed
2016-01-20 14:57 jmaustpc Assigned To => jmaustpc
2016-01-20 14:57 jmaustpc Resolution open => no change required
2017-01-15 02:20 Kunda1 Tag Detached: SIGSEGV
