| 0002428 | Path | Feature | public | 2016-01-30 16:11 | 2017-05-01 11:42 |
| Reporter | sliptonic | Assigned To | realthunder | ||
| Summary | 0002428: Path - Add direction arrows to Path command visualization. | ||||
| Description | Most modern CAM software will display the path backplot to visualize the tool movement relative to the model. This will include a visual cue to the direction of travel ie depicting a line with an embedded arrow head (---->-----). With FreeCAD's current implementation in Path, it isn't possible to determine the direction of travel by looking at the path. It would be best to allow a preference setting to toggle arrows on and off since they might be ineffective or distracting in very dense backplots. | ||||
c:FreeCAD:2f1880cf7b5cb51f6a8c69e869f21d339ba8bd2b |
@sliptonic needs to end with a ':' FreeCAD master 2f1880cf |
Closing. FYI @kkremitzki do u mind adding realthunder as a developer so we can credit him where it's due? (Like in this ticket) |
@Kunda1 @realthunder should be set up as a dev now. |
FreeCAD: master 2f1880cf 2017-03-17 08:22:55 Committer: wmayer Details Diff |
PathGui: enable ViewProviderPath pre-select Pre-select will show the corresponding GCode in the status bar, and also the direction of the movement. |
Affected Issues 0002428 |
| mod - src/Mod/Path/Gui/ViewProviderPath.cpp | Diff File | ||
| mod - src/Mod/Path/Gui/ViewProviderPath.h | Diff File | ||
| 2016-01-30 16:11 | sliptonic | New Issue | |
| 2016-01-30 17:13 | yorik | Summary | Add direction arrows to Path command visualization. => Path - Add direction arrows to Path command visualization. |
| 2016-02-23 14:15 | yorik | Assigned To | => yorik |
| 2016-02-23 14:15 | yorik | Status | new => assigned |
| 2016-03-22 15:19 | yorik | Project | FreeCAD => Path |
| 2017-03-20 19:10 | sliptonic | Status | assigned => resolved |
| 2017-03-20 19:10 | sliptonic | Resolution | open => fixed |
| 2017-03-20 19:10 | sliptonic | Fixed in Version | => 0.17 |
| 2017-03-20 19:10 | sliptonic | Note Added: 0008661 | |
| 2017-03-20 20:06 | Kunda1 | Note Added: 0008664 | |
| 2017-03-20 20:07 | Kunda1 | Changeset attached | => FreeCAD master 2f1880cf |
| 2017-04-28 19:26 | Kunda1 | Assigned To | yorik => wmayer |
| 2017-04-28 19:26 | Kunda1 | Status | resolved => closed |
| 2017-04-28 19:26 | Kunda1 | Note Added: 0008813 | |
| 2017-05-01 00:27 | kkremitzki | Note Added: 0008836 | |
| 2017-05-01 11:42 | Kunda1 | Assigned To | wmayer => realthunder |
