| 0002434 | Sketcher | Feature | public | 2016-02-03 03:53 | 2017-10-18 19:19 |
| Reporter | jmaustpc | Assigned To | wmayer | ||
| Platform | 64 bit | OS | Kubuntu | OS Version | 14.04 |
| Summary | 0002434: merge sketches produces sketch on XY plane when original sketches were on XZ | ||||
| Description | merging two sketches on the XZ plane will produce a sketch on the XY plane. | ||||
| Steps To Reproduce | create two new sketches, each time selecting the XZ plane in the creation dialogue, enter some simple geometry, use Sketcher "merge sketches", then result will correctly merge the elements within the sketch but mount the new merged sketch to the (default) XY plane. | ||||
| Additional Information | OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6274 (Git) Build type: Release Branch: master Hash: cbdd18cef6338038ed9e06a1773d4d55f231e46e Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
in a simple example where all the sketches are on the same plane the solution seems logical, the output merged sketch could logically be expected to be also placed on the same plane. However when sketches mounted on different planes are merged, then desired output could be less certain. Perhaps a solution could be to invoke a plane selection dialogue similar to that which pops up when you select "create new sketch" with nothing selected, and use that to select the desired output sketch plane? I have added a simple example file with four sketches, one each on each plane containing a 1, 2 or 3 and the result of 'merge sketches' which is on the xy plane. |
this is a link to the Help forum topic. http://forum.freecadweb.org/viewtopic.php?f=3&t=14105&p=112829#p112829 |
A clarification.....it makes no difference which face of a solid, or which plane, the original sketches were mapped to, the resultant new "merge" sketch will currently always be on XY plane. |
This should not be targeted for 0.16 if nobody will take the bug I think, otherwise it will delay 0.16 forever... I'll remove the target version for now |
Hi Yorik, I agree, Also this is really more of a feature request that a bug, I think, so leaving it until after 0.16 sounds appropriate to me. :-) |
Changed to 'Feature' |
@Abdullah thought? |
https://github.com/FreeCAD/FreeCAD/commit/f5b6694c83c3519e37f5905f95997e384760feff I think using the placement of the first sketch of the selection is a pragmatic way. |
| 2016-02-03 03:53 | jmaustpc | New Issue | |
| 2016-02-03 03:59 | jmaustpc | File Added: sketchplanesexamplemergersketches.fcstd | |
| 2016-02-03 04:04 | jmaustpc | Note Added: 0006800 | |
| 2016-02-03 04:07 | jmaustpc | Note Added: 0006801 | |
| 2016-02-03 08:13 | jmaustpc | Note Added: 0006802 | |
| 2016-02-12 16:13 | yorik | Note Added: 0006826 | |
| 2016-02-12 16:13 | yorik | Target Version | 0.16 => |
| 2016-02-13 12:55 | jmaustpc | Note Added: 0006829 | |
| 2017-02-08 12:42 | Kunda1 | Note Added: 0008238 | |
| 2017-02-08 12:42 | Kunda1 | Status | new => acknowledged |
| 2017-02-08 12:42 | Kunda1 | Category | Bug => Feature |
| 2017-07-08 14:36 | Kunda1 | Note Added: 0009679 | |
| 2017-09-25 08:12 | wmayer | Target Version | => 0.17 |
| 2017-10-18 19:19 | wmayer | Assigned To | => wmayer |
| 2017-10-18 19:19 | wmayer | Status | acknowledged => closed |
| 2017-10-18 19:19 | wmayer | Resolution | open => fixed |
| 2017-10-18 19:19 | wmayer | Fixed in Version | => 0.17 |
| 2017-10-18 19:19 | wmayer | Note Added: 0010322 |
