| 0002441 | PartDesign | Bug | public | 2016-02-07 20:22 | 2018-08-26 15:21 |
| Reporter | Tomas | Assigned To | abdullah | ||
| Summary | 0002441: Doing a pad of a sketch "Up to face" fails | ||||
| Description | Does not pad the entire way to the selected face. It is possible to pad by "dimension" instead so I cannot see why "up to face" wouldnt work. Thank you for a great software! | ||||
| Steps To Reproduce | In attaced file the last step. Pad008 of Sketch017 up to face "Face5" fails. | ||||
| Additional Information | Forum thread: https://forum.freecad.org/viewtopic.php?f=8&t=20461 | ||||
@Tomas please test on latest stable Also, when you reply, if you don't mind including your: 1) Help > About FreeCAD > Copy to clipboard 2) Create a forum thread and bi-directionally link ticket <=> thread |
Hello Kunda, Sorry I am not sure how all these forums work.. Tried to do the same operation now and in the attached figure I marked the face5 to wich I was trying to pad. As you can see the padding is still not reaching face5. BR Tomas |
@Tomas I've created a forum thread for you, see https://forum.freecad.org/viewtopic.php?f=8&t=20461 |
Tomas, Please read the READ THIS BEFORE REPORTING link in the "ISSUES" menu, it's just above "REPORT ISSUE" which you had to click to create this report. As explained in that link, we ask that users mention any potential bug on the forum *before* creating a report. Your model is rather complicated, and to validate this issue it would have been best to reproduce the bug with a model as simple as possible. @Kunda1 Tomas is already using the latest stable available on Windows as shown in his screenshot (0.16.6706). Agreed that it's best to provide this info in text format. |
I confirm the problem on Tomas' model, but I'm unable to reproduce this issue on simpler test cases. I will have to analyze Tomas' model further. OS: Ubuntu 14.04.5 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6707 (Git) Build type: None Branch: releases/FreeCAD-0-16 Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
Tomas, The use of a Part --> Refine shape on Pocket003, resulting in Pocket004, has broken your model's history. Part Refine shape creates an independent solid that is not linked to the object it's based to. It is bad practice to base further operations on such an object. The LinearPattern feature produces an invalid solid with self-intersect errors. This can be seen by using Part Check Geometry with extra BOP check (https://www.freecad.org/wiki/index.php?title=Part_CheckGeometry) There may be a bug here, but to confirm we would need a model with no errors to begin with. Which is why this should be addressed in the forum first, for which this tracker is not the proper place. |
@Kunda1 Thanks! I tried to correct the linear pattern operation that obviously created a non-valid object but after that the changes I made did not follow on in the rest of the operations and in the end I was there with just a bunch of disaster. I am sorry guys, I am like a grandpa compared to you when it comes to freecad. I have already made a fool of myself to normandc once this week.. Maybe we should just drop this Issue. I thank you for a nice software and a great effort. BR Tomas |
@normandc can you try to reproduce the bug without the example model? |
@Kunda1 I'm afraid I can't. |
If I open the original file, the padding goes up to face. Then I can no longer work with the model with 0.17, as it is not PDN. I am closing this ticket as we can not reproduce the bug. @Tomas I make a fool of myself everyday. If you happen to find any bug, try to report it following the procedure. It is in place so that very competent people, like Normand makes sure it is a bug and help you shape the form of the bug report. It saves time for everybody, specially for developers. I hope to see you around again :) |
| 2016-02-07 20:22 | Tomas | New Issue | |
| 2016-02-07 20:22 | Tomas | File Added: värmeväxlare.FCStd | |
| 2017-02-02 01:26 | Kunda1 | Note Added: 0008163 | |
| 2017-02-02 01:26 | Kunda1 | Status | new => feedback |
| 2017-02-03 18:02 | Tomas | File Added: version.jpg | |
| 2017-02-03 18:02 | Tomas | File Added: face5.jpg | |
| 2017-02-03 18:04 | Tomas | Note Added: 0008194 | |
| 2017-02-03 18:04 | Tomas | Status | feedback => new |
| 2017-02-03 20:56 | Kunda1 | File Deleted: version.jpg | |
| 2017-02-03 20:56 | Kunda1 | File Added: version.jpg | |
| 2017-02-03 20:58 | Kunda1 | File Deleted: face5.jpg | |
| 2017-02-03 20:58 | Kunda1 | File Added: face5-1.jpg | |
| 2017-02-03 21:02 | Kunda1 | Additional Information Updated | |
| 2017-02-03 21:02 | Kunda1 | Tag Attached: #pending | |
| 2017-02-03 21:03 | Kunda1 | Note Added: 0008195 | |
| 2017-02-04 04:47 | normandc | Note Added: 0008204 | |
| 2017-02-04 04:53 | normandc | Note Added: 0008205 | |
| 2017-02-04 05:08 | normandc | Note Added: 0008206 | |
| 2017-02-04 12:18 | Kunda1 | Status | new => feedback |
| 2017-02-05 20:28 | Tomas | Note Added: 0008220 | |
| 2017-02-05 20:28 | Tomas | Status | feedback => new |
| 2017-09-24 15:36 | wmayer | Status | new => confirmed |
| 2017-09-24 15:36 | wmayer | Target Version | => 0.17 |
| 2017-12-07 11:57 | Kunda1 | Note Added: 0010542 | |
| 2017-12-31 13:57 | normandc | Note Added: 0010646 | |
| 2018-01-02 17:47 | abdullah | Note Added: 0010673 | |
| 2018-01-02 17:47 | abdullah | Assigned To | => abdullah |
| 2018-01-02 17:47 | abdullah | Status | confirmed => closed |
| 2018-01-02 17:47 | abdullah | Resolution | open => unable to reproduce |
| 2018-01-02 17:47 | abdullah | Fixed in Version | => 0.17 |
| 2018-01-05 21:58 | wmayer | Relationship added | related to 0003141 |
| 2018-08-26 15:21 | Kunda1 | Tag Detached: #pending |
