| 0002452 | FreeCAD | Bug | public | 2016-02-19 18:42 | 2016-04-12 16:33 |
| Reporter | Kompilainenn | Assigned To | wmayer | ||
| Platform | x86 | OS | Windows | OS Version | 7 |
| Summary | 0002452: Don't started FreeCAD after install in Windows 7 with locale ru_RU | ||||
| Description | subj | ||||
| Steps To Reproduce | 1. install FreeCAD 0.15 2. start FreeCAD 3. See on error -> http://forum.freecad.org/download/file.php?id=20472, push OK. 4. FreeCAD don't started =( | ||||
| Additional Information | locale ru_RU | ||||
That's a known problem. Your system path environment variable contains some characters with their ordinal numbers in the range [128, 255] which Python has problems with. There are two methods to fix it: 1. Switch to one of the 0.16 pre-release versions 2. Create a FreeCAD.bat file and add this content to it: set PATH= start FreeCAD.exe %1 Afterwards you have to double-click the FreeCAD.bat file See also: http://forum.freecad.org/viewtopic.php?t=12065&start=10 http://forum.freecad.org/viewtopic.php?t=11176&start=10 |
| 2016-02-19 18:42 | Kompilainenn | New Issue | |
| 2016-02-20 09:30 | wmayer | Note Added: 0006839 | |
| 2016-02-20 09:31 | wmayer | Relationship added | duplicate of 0002238 |
| 2016-02-20 09:31 | wmayer | Assigned To | => wmayer |
| 2016-02-20 09:31 | wmayer | Status | new => feedback |
| 2016-04-12 16:33 | wmayer | Status | feedback => closed |
| 2016-04-12 16:33 | wmayer | Resolution | open => no change required |
| 2016-04-12 16:33 | wmayer | Fixed in Version | => 0.16 |
