| 0002238 | FreeCAD | Bug | public | 2015-09-02 10:38 | 2021-04-11 13:48 |
| Reporter | gozreh | Assigned To | wmayer | ||
| Platform | 64 Bit (i7-3740QM ) | OS | Windows | OS Version | 7 Ultimate |
| Summary | 0002238: Python: Environment Variable 'path' with mutated vowel (german: Umlaut [äöüß]) | ||||
| Description | If the path contain a non-ascii character obove 127 the function Py_Initialize() fails with no return value. Therefore the user is left alone with this problem. | ||||
| Steps To Reproduce | 1. Add 'path' with a character 'ü' in it. 2. Start FreeCad | ||||
| Additional Information | Tested with character 'ü'. | ||||
YMMD! This is a nasty bug which also regularly appears in the forum and I could never reproduce it. However, for me it doesn't corrupt Py_Initialize but it much later throws an exception in the built-in script FreeCADInit.py at the line: os.environ["PATH"] = PathExtension + os.environ["PATH"] You can also demonstrate this problem directly in Python. 1. Open a terminal and enter e.g.: set PATH=%PATH%;C:\Temp\äöü 2. Start a Python session with python.exe 3. In the Python prompt enter: import os "test"+os.environ["PATH"] ## => nothing happens 4. Now enter this: u"test"+os.environ["PATH"] ## => UnicodeDecodeError: 'ascii' codec can't decode byte 0xe4 in position 734: ordinal not in range(128) |
@wmayer do you mind reviewing this now that we're fully ported to Py3 ?
source: https://github.com/FreeCAD/FreeCAD/blob/5d49bf78de785a536f941f1a6d06d432582a95d3/src/App/FreeCADInit.py#L67 |
| 2015-09-02 10:38 | gozreh | New Issue | |
| 2015-09-05 11:02 | wmayer | Note Added: 0006333 | |
| 2015-09-05 12:53 | wmayer | Changeset attached | => FreeCAD Master master 4da63d1d |
| 2015-09-05 12:53 | wmayer | Assigned To | => wmayer |
| 2015-09-05 12:53 | wmayer | Status | new => closed |
| 2015-09-05 12:53 | wmayer | Resolution | open => fixed |
| 2015-12-15 13:17 | yorik | Fixed in Version | => 0.16 |
| 2016-02-20 09:31 | wmayer | Relationship added | has duplicate 0002452 |
| 2021-04-11 13:48 | Kunda1 | Note Added: 0015606 |
