| 0002457 | Raytracing | General | public | 2016-02-27 18:21 | 2020-12-05 07:24 |
| Reporter | drei | Assigned To | howetuft | ||
| Platform | GNU Linux | OS | Arch Linux | OS Version | 64 bit |
| Summary | 0002457: Add an option in Raytracing preferences to toggle between adding hard coded presets or not | ||||
| Description | Currently, whenever a POV file is created FreeCAD automatically appends the camera settings that are hard coded into the routines. Some users would like to have absolute control of this, either through manually coding them or using a template. Any chance a preference setting could be added to the workbench to toggle this behaviour? | ||||
| Steps To Reproduce | In Raytracing, after creating the scene, select export POV file. Examining the code shows that FreeCAD has already added camera presets, even when the template defines them as well. | ||||
| Tags | Raytracing | ||||
@kunda1 Is this ticket "Sketcher" related? Do we need a Raytracing project? :) |
@howetuft care to weigh in on this ticket as well? Thanks :) |
Render WB has a Camera feature, which is fully configurable. Camera settings (position, direction, FOV...) are no longer hard-coded in the template, but controlled in the model. This ticket can be closed! |
| 2016-02-27 18:21 | drei | New Issue | |
| 2016-02-27 19:02 | yorik | Assigned To | => yorik |
| 2016-02-27 19:02 | yorik | Status | new => assigned |
| 2017-02-02 21:18 | Kunda1 | Tag Attached: Raytracing | |
| 2017-12-12 15:38 | abdullah | Note Added: 0010591 | |
| 2017-12-18 01:16 | Kunda1 | Project | Sketcher => Raytracing |
| 2017-12-18 01:16 | Kunda1 | Category | Feature => General |
| 2018-01-11 15:58 | yorik | Target Version | => 0.18 |
| 2019-02-14 21:23 | wmayer | Target Version | 0.18 => 0.19 |
| 2020-12-03 22:43 | Kunda1 | Assigned To | yorik => howetuft |
| 2020-12-03 22:43 | Kunda1 | Note Added: 0015064 | |
| 2020-12-05 07:23 | howetuft | Note Added: 0015082 | |
| 2020-12-05 07:24 | howetuft | Status | assigned => closed |
| 2020-12-05 07:24 | howetuft | Resolution | open => fixed |
