0002478FreeCADBugpublic2017-01-16 22:39
Reportermcgiwer Assigned To
Platformi686OSUbuntuOS Version14.10
Product Version0.15
Summary0002478: Grying out after all window close
DescriptionAfter closing all windows (function "Close all") almost anything (including almost all menu entries) is gryed out (disabled) and it's not possible to do anything (creating new file openinig file, closing program, etc.) till forcing the program to close and re-opening it
Steps To Reproduce1. open (or create new) file
2. use the File -> Close all
3. try to repeat the step 1. or exit the program from menu
Additional InformationIssue showed up on Ubuntu 14.10
2016-03-16 17:25
administrator   ~0006908
When using "Close All" then all documents will be closed (after confirmation of modified documents). Afterwards only commands that do not rely on an existing document are working (File > New, File > Open, ...) and the vast majority is greyed out because it doesn't make sense to have them activated otherwise.
So, why is this considered as bug?
mcgiwer
2016-03-16 18:16
reporter   ~0006911
I had reported it as bug because making impossible to open, create new or exit FreeCad when all edit like windows are closed make no sense (the program can be closed only by killing the process from command line or task manager)
2016-03-17 17:28
administrator   ~0006913
But as said above the commands Open, New and Exit *are* active after using "Close all". Maybe there is something wrong with Ubuntu 14.10?
On one system I have installed the Cinnamon desktop and there I sometimes have the situation that a menu item looks disabled but it's not. So maybe you can try to click on the item even if it looks disabled.
2017-01-13 16:55
administrator   ~0007721
@mcgiwer can you retest on a more recent version of FreeCAD?
Also include data from Help > About FreeCAD
Thx
mcgiwer
2017-01-13 21:42
reporter   ~0007733
@Kunda1 I think that the person who's responsible for maintanancing the repositories for Linux (Debian, Ubuntu, etc.) should keep updating them more frequent because such ones get quickly outdated.
I will test it on the Ubuntu 16.10. Mayby it would help me to verify if this bug still exist
2017-01-13 21:50
administrator   ~0007734
mcgwier, yes, please test it on 16.10
debian is famous for having slow release cycles. I think there is a PPA you can also try.
Either way, I don't think you'll be able to reproduce.
I can't reproduce on:
OS: "Manjaro Linux"
Version: 0.16.Unknown
Python version: 2.7.12
Qt version: 4.8.7
Coin version: 3.1.3
OCC version: 6.9.1
I'll resolve this issue for now. If you can reproduce please reopen
2016-03-15 19:16 mcgiwer New Issue
2016-03-15 19:17 mcgiwer Tag Attached: freecad
2016-03-16 17:25 wmayer Note Added: 0006908
2016-03-16 17:25 wmayer Status new => feedback
2016-03-16 18:16 mcgiwer Note Added: 0006911
2016-03-16 18:16 mcgiwer Status feedback => new
2016-03-17 17:28 wmayer Note Added: 0006913
2017-01-13 16:55 Kunda1 Note Added: 0007721
2017-01-13 16:55 Kunda1 Status new => feedback
2017-01-13 16:56 Kunda1 Tag Detached: freecad
2017-01-13 21:42 mcgiwer Note Added: 0007733
2017-01-13 21:42 mcgiwer Status feedback => new
2017-01-13 21:50 Kunda1 Note Added: 0007734
2017-01-13 21:50 Kunda1 Status new => resolved
2017-01-13 21:50 Kunda1 Resolution open => unable to reproduce
2017-01-13 21:50 Kunda1 Assigned To => Kunda1
2017-01-16 22:39 wmayer Status resolved => closed
2017-01-16 22:39 wmayer Assigned To Kunda1 =>
