| 0002479 | Arch | Bug | public | 2016-03-16 14:54 | 2017-01-30 15:46 |
| Reporter | lanciaux | Assigned To | yorik | ||
| Summary | 0002479: Arch / Windows tool not taking account of ALIGN setting | ||||
| Description | When using ARCH/Window tool to add a window, windows is not located correctly "inside the wall" if you do not choose ALIGN=CENTER | ||||
| Steps To Reproduce | I have just build a rectangle with dimensions 4000 / 2000 mm. I select face and unfill it (notice when drawing a rectangle with ARCH, dialog box FILLED setting is blank (OFF ?) but rectangle is filled when releasing mouse) with rectangle selected, I choose wall tool with wall selected, I change ALIGN=center to ALIGN=right with wall selected, I add a window that sets naturally at base of walls (rectangle) Windows is outside volume of the wall and not inside wall (Same kind of issue with ALIGN=Left) | ||||
I cannot reproduce the problem, the window seems correctly placed for me, on a wall with align=right. Can you check if the problem still happens with a recent version of FreeCAD? |
@lanciaux please respond |
Since reported that it was not reproducible and OP has not replied to ticket. Resolving as 'unable to reproduce'. |
| 2016-03-16 14:54 | lanciaux | New Issue | |
| 2016-03-16 14:54 | lanciaux | File Added: FreeCAD_BUG_Arch_WindowTool.fcstd | |
| 2016-05-13 03:56 | yorik | Note Added: 0007087 | |
| 2016-05-13 03:56 | yorik | Assigned To | => yorik |
| 2016-05-13 03:56 | yorik | Status | new => feedback |
| 2017-01-16 08:01 | Kunda1 | Note Added: 0007805 | |
| 2017-01-23 20:31 | Kunda1 | Tag Attached: #pending | |
| 2017-01-29 15:16 | Kunda1 | Note Added: 0008080 | |
| 2017-01-29 15:16 | Kunda1 | Status | feedback => resolved |
| 2017-01-29 15:16 | Kunda1 | Resolution | open => unable to reproduce |
| 2017-01-30 15:36 | yorik | Status | resolved => closed |
| 2017-01-30 15:46 | Kunda1 | Tag Detached: #pending |
