| 0002484 | Path | Bug | public | 2016-03-30 00:55 | 2017-02-15 18:48 |
| Reporter | sliptonic | Assigned To | yorik | ||
| Platform | All | OS | All | OS Version | All |
| Summary | 0002484: Empty Paths not correctly rendered | ||||
| Description | If a Path operation has all commands removed, it will continue to show the old backplot and cannot be cleared. | ||||
| Steps To Reproduce | This affects all path types but is easy to reproduce by creating a path based on custom gcode. 1) start the path workbench. 2) click the path based on custom gcode 3) Edit the gcode text and put in a couple movement commands G0 X10 Y10 G1 X15 Y15 4) Save the commands 5) refresh the document and see the backplot. 6) reedit the gcode and delete the commands. 7) refresh the document. You will expect the backplot to disappear but it does not. Only adding new commands will change the display. | ||||
| Additional Information | This wasn't a problem before because we never had paths with empty base objects. With the taskpanels I'm building to allow user to modify base without deleting the operation it is likely and confusing. I've even tried replacing the commands with a comment command: (here is a comment) but this doesn't cause backplot to be re-rendered. | ||||
this should be easy to fix |
This issues still occurs related to compound (Job) view if there are no operations left active. Easy to reproduce: 1) Create a job. 2) Create an operation (ie profile from face) so a path is displayed on the screen 3) Delete the operation or toggle it inactive. 4) The path backplot is still shown. If there are other active operations in the job, the backplot is redrawn but if not, the old one remains. |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19938 |
sliptonic writes in gitter.im > ... It's more annoying than anything and the solution is in the C++ so I'm not qualified. Maybe @mlampert can take a look when his day gig lightens up a bit. |
Another clue I noticed about this: If you've got a Path Compound that has a child that generates gcode but no moves (ie, maybe a couple commands with comments or tool changes but no g0/g1/g2/g3 moves, then it doesn't correctly update. The compound continues to show whatever moves it was showing before. However, If the compound is truly empty, ie the Path has zero commands in it, then it updates correctly. Here's a macro that shows the effect easily. After you run the macro, you'll still see the old backplot from the compound. But set the compound Path=emptypath and it clears: import Path snippet = '''p1 = Path.Path("G1X1") o1 = App.ActiveDocument.addObject("Path::Feature","path1") o1.Path=p1 p2 = Path.Path("G1Y1") o2 = App.ActiveDocument.addObject("Path::Feature","path2") o2.Path=p2 p3 = Path.Path('(empty comment)') o3 = App.ActiveDocument.addObject("Path::Feature","nonmove") o3.Path=p3 compound = App.ActiveDocument.addObject("Path::FeatureCompound","compound") compound.Group=[o1,o2,o3] emptypath = Path.Path() App.ActiveDocument.recompute() print(compound.Path.toGCode()) o1.Path = emptypath o2.Path = emptypath App.ActiveDocument.recompute() print(compound.Path.toGCode()) ''' FreeCADGui.doCommand(snippet) |
FreeCAD: master 40b00e55 2016-10-01 00:35:26 Details Diff |
Path: remove old dislay if path becomes empty - fixes 0002484 |
Affected Issues 0002484 |
| mod - src/Mod/Path/Gui/ViewProviderPath.cpp | Diff File | ||
FreeCAD: master c1dad1bd 2017-02-15 17:40:25 Details Diff |
Path: Fixed wrong display of non-displayable paths - fixes 0002484 |
| 2016-03-30 00:55 | sliptonic | New Issue | |
| 2016-03-30 14:58 | yorik | Note Added: 0006936 | |
| 2016-03-30 14:59 | yorik | Assigned To | => yorik |
| 2016-03-30 14:59 | yorik | Status | new => assigned |
| 2016-09-30 22:35 | yorik | Changeset attached | => FreeCAD Master master 40b00e55 |
| 2016-09-30 22:35 | yorik | Status | assigned => closed |
| 2016-09-30 22:35 | yorik | Resolution | open => fixed |
| 2016-11-03 22:45 | sliptonic | Note Added: 0007439 | |
| 2016-11-03 22:45 | sliptonic | Status | closed => feedback |
| 2016-11-03 22:45 | sliptonic | Resolution | fixed => reopened |
| 2017-01-16 08:14 | Kunda1 | Note Added: 0007808 | |
| 2017-01-28 13:35 | Kunda1 | Note Added: 0008056 | |
| 2017-02-15 15:54 | sliptonic | Note Added: 0008308 | |
| 2017-02-15 15:54 | sliptonic | Status | feedback => assigned |
| 2017-02-15 15:54 | sliptonic | Note Edited: 0008308 | |
| 2017-02-15 15:56 | sliptonic | Note Edited: 0008308 | |
| 2017-02-15 17:40 | yorik | Changeset attached | => FreeCAD Master master c1dad1bd |
| 2017-02-15 17:40 | yorik | Status | assigned => closed |
| 2017-02-15 18:48 | Kunda1 | Fixed in Version | => 0.17 |
| 2017-02-15 18:48 | Kunda1 | Target Version | => 0.17 |
