| 0002485 | FreeCAD | Bug | public | 2016-03-30 17:20 | 2019-01-13 11:13 |
| Reporter | mandeep7 | Assigned To | mandeep7 | ||
| Platform | Linux | OS | Arch Linux 4.4.5-1 | OS Version | x86_64 |
| Summary | 0002485: Checkboxes "Line numbers" and "Folding" in editor preferences, not working | ||||
| Description | While creating a new macro or editing an existing one, an editor to write code for the macro opens. It already has the line numbers and the current line highlighted. Then I go to Edit -> Preferences -> Editor -> Options -> "Untick", Enable line numbers -> Apply -> OK. But it won't disable the line numbers from the editor. | ||||
| Steps To Reproduce | 1. Open FreeCAD. 2. Press the "Macro" button from the menu. 3. Then in the submenu, click on "Macros ..." button. 4. Click on "Create", Enter any name and press OK. (or one may also edit the existing macro). 5. This will open the macro editor. 6. Now click on the Edit -> Preferences -> Editor from the menu. 7. Untick the Enable line numbers. It was supposed to disable the line numbers by doing the above steps. Similar is the case for the "Folding" checkbox. | ||||
| Additional Information | Arch Linux Qt 5.5.1 | ||||
| Tags | macros | ||||
| related to | 0000573 | new | Macro editing FCMacro file - 4 improvements |
Indeed these two features don't seem to be enabled. Do you want to work on this Mandeep? |
Yes, I am working on it. You may assign me this. I already added a note, yesterday. Don't know why it wasn't appeared here. |
Done. https://github.com/FreeCAD/FreeCAD/pull/142 |
I updated your status on this tracker to "developer" Mandeep (this will be useful for the GSOC ;) ) so you can now attribute issues to yourself and close them. I don't know if you wish to work further on this so I let you close it. |
Thanks. The line number one has been fixed (as of now). As I already discussed with stefan and werner, about the folding one. It's not yet implemented yet and is a redundant option (from old code). And needs much work to do. As it will be a complete rework, it was suggested to look for compatible editors that can be used or just to comment out the code for this option (as for now). |
The Python IDE Spyder has a nice editor which is under the MIT license. So, what we could try is that when Spyder is found on the system then its editor will be used (not sure how difficult this is to do). If it's not there we can fall back to our editor. Alternatively, we can also extract the relevant code from Spyder and copy it to FreeCAD. But we should only do this if it's not more than a few files. If we needed to copy dozens of files from Spyder then we shouldn't follow this approach. On the other hand we could still try to improve our editor. What it least needs is: * folding * search function |
We could also simply add a preferences setting, where the user can specify (the path to) his own favorite editor. This could be really simple... |
Yorik, you mean having both Spyder and the one we already have? |
Yes. I mean have a checkbox in the preferences that says "edit macros in external editor" and an input field where you can set the path to your favorite editor. This would allow one to use a full editor with all the whistles and bells. But I also think like Werner, we also need to add a couple of things in our own editor. |
Okay, will discuss with you later today (IRC). Now need a little nap. |
bump @mandeep7 going through the bugtracker and ascertaining the status of tickets. please advise the status, thanks! |
| 2016-03-30 17:20 | mandeep7 | New Issue | |
| 2016-03-30 17:27 | mandeep7 | Tag Attached: macros | |
| 2016-03-30 17:27 | mandeep7 | Tag Attached: editor preferences | |
| 2016-03-30 17:27 | mandeep7 | Tag Attached: folding | |
| 2016-03-30 17:27 | mandeep7 | Tag Attached: line numbers | |
| 2016-03-30 21:07 | yorik | Note Added: 0006937 | |
| 2016-03-31 16:14 | mandeep7 | Note Added: 0006939 | |
| 2016-04-19 19:38 | mandeep7 | Note Added: 0006991 | |
| 2016-04-26 22:48 | yorik | Note Added: 0007008 | |
| 2016-04-26 22:48 | yorik | Assigned To | => mandeep7 |
| 2016-04-26 22:48 | yorik | Status | new => assigned |
| 2016-04-27 15:37 | mandeep7 | Note Added: 0007012 | |
| 2016-04-28 10:46 | wmayer | Note Added: 0007013 | |
| 2016-04-28 13:17 | yorik | Note Added: 0007014 | |
| 2016-04-28 23:33 | mandeep7 | Note Added: 0007025 | |
| 2016-04-29 00:55 | yorik | Note Added: 0007026 | |
| 2016-04-29 00:59 | mandeep7 | Note Added: 0007027 | |
| 2017-01-10 15:08 | Kunda1 | Note Added: 0007600 | |
| 2017-01-10 15:18 | mandeep7 | Status | assigned => closed |
| 2017-01-10 15:18 | mandeep7 | Resolution | open => fixed |
| 2017-02-02 14:12 | Kunda1 | Relationship added | related to 0000573 |
| 2018-12-24 12:48 | Kunda1 | Tag Detached: line numbers | |
| 2018-12-24 12:49 | Kunda1 | Tag Detached: folding | |
| 2019-01-13 11:13 | Kunda1 | Tag Detached: editor preferences |
