0002493PartDesignBugpublic2017-10-01 22:59
Reporterbibomator Assigned Towmayer
Status closedResolutionfixed
PlatformLinuxOSLinuxOS VersionLinux Mint 17.1
Product Version0.16
Target Version0.17Fixed in Version0.17
Summary0002493: [0.16] crash when adding slot
Descriptionafter adding a slot in the sketch and ending the creation Freecad crashes
Steps To Reproduce1) open attached file
2) Open the Sketch "Sketch"
3) Switch to Part designer
4) Add a slot to the sketch
5) press escape to exit the slot dialog
--> Program will crash within some seconds
Relationships
related to 0002672 closedkkremitzki Sketcher Sketcher symmetry tool segfaults
bibomator
2016-04-04 20:17
reporter
bosch_konsole3.fcstd (Attachment missing)
eivindkvedalen
2016-04-04 20:29
developer   ~0006944
Confirmed with assertion FreeCAD: SoGroup.cpp:292: virtual SoNode* SoGroup::getChild(int) const: Assertion `(index >= 0) && (index < this->getNumChildren())' failed.
maiden
2016-12-01 21:21
reporter
A2212Attachment1.fcstd (Attachment missing)
maiden
2016-12-01 21:23
reporter   ~0007503
I get the exact same fault with the appended file, open file, in part design try to create a sketch on the surface with the hole, then draw a rect on the sketch and it will crash. running latest git on Ubuntu 16.10
maiden
2016-12-02 12:02
reporter   ~0007505
Ah, made a git clean, followed by "make clean", that resolved the problem for me. turned out i had 20+ old .cpp, .py and .h files that was no longer in the git repo.
maiden
2016-12-03 13:14
reporter   ~0007511
got the issue again on the new build.
normandc
2016-12-16 03:15
manager   ~0007527
maiden, "the new build" is meaningless. Please provide your full FreeCAD info as explaining here: http://forum.freecad.org/viewtopic.php?f=3&t=2264
Your file's Dependency Graph looks very weird as there are arrows pointing to Pad from Pocket and Sketch001, they shouldn't be there. Please explain in detail how you built this model.
FreeCAD info should look like this:
OS: Ubuntu 14.04.5 LTS
Version: 0.17.9244 (Git)
Build type: None
Hash: 6d1eddc22f9f3176cea96b34d5002e84e29550d4
Python version: 2.7.6
Qt version: 4.8.6
OCC version: 6.8.0.oce-0.17
2017-01-13 20:44
administrator   ~0007728
@bibomator please respond to @normandc queries in 0002493:0007527
maiden
2017-01-16 08:11
reporter   ~0007807
I think it might be related to the issue i described here:
http://forum.freecad.org/viewtopic.php?f=10&t=18985&p=147992#p147992
OS: Ubuntu 16.10
Version: 0.17.9586 (Git)
Build type: Unknown
Hash: 0e2cf2ebcaaa50723de608cf030af740cb6ad548
Python version: 2.7.12+
Qt version: 4.8.7
2017-01-16 08:30
administrator   ~0007811
@bibomator could you also provide a detailed step-by-step as was requested above? Just linking to that forum thread might not be enough for the devs to ascertain the issue. Thanks
bibomator
2017-01-17 18:57
reporter   ~0007844
@Kunda1
I can't explain what the User maiden did and how he constructed the model. I just can speak for the model saved in file bosch_konsole3.fcstd which was created by me (the other attachment was not) hence I cant explain /view.php?id=2493#c7527
I just could reproduce the crash with my latest installation which is 0.16, Git 6707 following the steps in the field "steps to reproduce"
1) open attached file (bosch_konsole3.fcstd)
The slot is not added and after some time the program crashes.
Please describe what additional information you need.
2017-01-17 19:46
administrator   ~0007846
@bibomator please paste the output from Help > About FreeCAD > Copy to clipboard
bibomator
2017-01-17 19:50
reporter   ~0007847
OS: Ubuntu 16.04.1 LTS
Version: 0.16.6707 (Git)
Build type: None
Branch: releases/FreeCAD-0-16
Hash: 5465bc47c95db45e0be85dc0e2872419efadce0f
Qt version: 4.8.7
2017-01-18 02:05
administrator   ~0007862
Thanks @bibomator
@eivindkvedalen wrote in 0002493:0006944
2017-04-28 12:07
administrator   ~0008795
@kkremitzki can you please move this in to 'Part' category? ( I believe that is correct, right?) Thx!
kkremitzki
2017-05-16 14:45
administrator   ~0009032
@Kunda1 moved
normandc
2017-06-18 01:04
manager   ~0009440
It's not correct. This has nothing to do with Part, the two people affected by this bug very clearly mention the PartDesign workbench.
The bosch_konsole3.fcstd file is no longer available. I cannot confirm this issue.
2017-06-18 19:31
administrator   ~0009452
@normandc my bad. Thanks for the correction.
@bibomator can you re-up your original attachment? It didn't survive a restore we needed to run on the tracker. Thanks in advance!
2017-07-03 21:16
administrator   ~0009659
@bibomator ping
2017-09-22 19:46
administrator   ~0010157
@bibomator ping
bibomator
2017-09-23 08:12
reporter   ~0010160
Hi - sorry I don't have the file which cause the crash anymore. I recreated the design after fileing the bug but didn't think about preserving the file...
2017-09-24 11:33
administrator   ~0010166
@wmayer please advise on how to proceed with this ticket (since we don't have the example file anymore to trigger the bug)?
2017-09-25 20:48
administrator   ~0010193
I assume the issue has been fixed with this change: https://github.com/FreeCAD/FreeCAD/commit/3d86498a43568770c619427169951535d8e3ba4e#diff-0e7a6053fe9b35a7f7445e53ce49d08e
2017-09-26 15:14
administrator   ~0010194
A-OK, resolving then and deferring to dev to close it.
2016-04-04 20:17 bibomator New Issue
2016-04-04 20:17 bibomator File Added: bosch_konsole3.fcstd
2016-04-04 20:29 eivindkvedalen Note Added: 0006944
2016-12-01 21:21 maiden File Added: A2212Attachment1.fcstd
2016-12-01 21:23 maiden Note Added: 0007503
2016-12-02 12:02 maiden Note Added: 0007505
2016-12-03 13:14 maiden Note Added: 0007511
2016-12-16 03:15 normandc Note Added: 0007527
2016-12-16 03:15 normandc Note Edited: 0007527
2017-01-13 20:44 Kunda1 Note Added: 0007728
2017-01-13 20:44 Kunda1 Status new => feedback
2017-01-16 08:11 maiden Note Added: 0007807
2017-01-16 08:15 maiden Note Edited: 0007807
2017-01-16 08:17 maiden Note Edited: 0007807
2017-01-16 08:30 Kunda1 Note Added: 0007811
2017-01-16 08:30 Kunda1 Status feedback => new
2017-01-16 08:31 Kunda1 Note Edited: 0007811
2017-01-16 08:31 Kunda1 Status new => feedback
2017-01-17 18:57 bibomator Note Added: 0007844
2017-01-17 18:57 bibomator Status feedback => new
2017-01-17 19:46 Kunda1 Note Added: 0007846
2017-01-17 19:46 Kunda1 Status new => feedback
2017-01-17 19:50 bibomator Note Added: 0007847
2017-01-17 19:50 bibomator Status feedback => new
2017-01-18 02:05 Kunda1 Note Added: 0007862
2017-01-23 22:12 wmayer Relationship added related to 0002672
2017-02-15 06:00 kkremitzki Status new => confirmed
2017-02-15 06:00 kkremitzki Target Version => 0.17
2017-04-28 12:07 Kunda1 Note Added: 0008795
2017-04-28 12:08 Kunda1 Product Version => 0.16
2017-05-16 14:44 kkremitzki Project FreeCAD => Part
2017-05-16 14:45 kkremitzki Note Added: 0009032
2017-06-18 01:04 normandc Note Added: 0009440
2017-06-18 01:04 normandc Project Part => PartDesign
2017-06-18 19:31 Kunda1 Status confirmed => feedback
2017-06-18 19:31 Kunda1 Note Added: 0009452
2017-06-18 19:32 Kunda1 Note Edited: 0009452
2017-07-03 21:16 Kunda1 Note Added: 0009659
2017-09-22 19:46 Kunda1 Note Added: 0010157
2017-09-23 08:12 bibomator Note Added: 0010160
2017-09-23 08:12 bibomator Status feedback => new
2017-09-24 11:33 Kunda1 Note Added: 0010166
2017-09-25 20:48 wmayer Note Added: 0010193
2017-09-26 15:14 Kunda1 Assigned To => wmayer
2017-09-26 15:14 Kunda1 Status new => resolved
2017-09-26 15:14 Kunda1 Resolution open => fixed
2017-09-26 15:14 Kunda1 Fixed in Version => 0.17
2017-09-26 15:14 Kunda1 Note Added: 0010194
2017-10-01 22:59 wmayer Status resolved => closed
