| 0002496 | Draft | Bug | public | 2016-04-06 01:18 | 2017-08-28 18:17 |
| Reporter | sliptonic | Assigned To | yorik | ||
| Summary | 0002496: DraftGeomUtils.FindWires doesn't find all | ||||
| Description | Passing in a set of edges to DraftGeomUtils.findWires(), I would expect to get back a list of all wires in the set. However, an incomplete set is returned under some conditions. | ||||
| Steps To Reproduce | Run this macro: import DraftGeomUtils App.ActiveDocument.addObject("Part::Box","Box") App.ActiveDocument.ActiveObject.Label = "Cube" App.ActiveDocument.recompute() obj = App.ActiveDocument.ActiveObject print "The box object has " + str(len(obj.Shape.Edges)) + " edges" print "length of obj.Shape.Wires: " + str(len(obj.Shape.Wires)) x =0 for f in obj.Shape.Faces: x += len(f.Wires) print "Total found by counting wires in object faces: " + str(x) print "wires found by DraftGeomUtils.findWires(obj.Shape.Edges) : " + str(len(DraftGeomUtils.findWires(obj.Shape.Edges))) | ||||
| Additional Information | output on my system: The box object has 12 edges length of obj.Shape.Wires: 6 Total found by counting wires in object faces: 6 wires found by DraftGeomUtils.findWires(obj.Shape.Edges) : 1 | ||||
will look into it |
Opened forum thread: https://forum.freecadweb.org/viewtopic.php?f=8&t=24099 |
I have replied on a forum. |
@sliptonic can you retest and see if this issue still exists for you? It seems @amrit3701 can't reproduce it. |
re-ran test. No longer shows incorrect results. No idea when it was fixed. |
Closing |
| 2016-04-06 01:18 | sliptonic | New Issue | |
| 2016-04-26 22:50 | yorik | Note Added: 0007009 | |
| 2016-04-26 22:50 | yorik | Assigned To | => yorik |
| 2016-04-26 22:50 | yorik | Status | new => assigned |
| 2017-08-28 16:24 | Kunda1 | Note Added: 0010027 | |
| 2017-08-28 17:56 | amrit3701 | Note Added: 0010028 | |
| 2017-08-28 18:06 | Kunda1 | Note Added: 0010029 | |
| 2017-08-28 18:10 | sliptonic | Status | assigned => resolved |
| 2017-08-28 18:10 | sliptonic | Resolution | open => fixed |
| 2017-08-28 18:10 | sliptonic | Fixed in Version | => 0.17 |
| 2017-08-28 18:10 | sliptonic | Note Added: 0010030 | |
| 2017-08-28 18:17 | Kunda1 | Status | resolved => closed |
| 2017-08-28 18:17 | Kunda1 | Note Added: 0010031 |
