| 0002498 | Part | Feature | public | 2016-04-09 19:53 | 2017-08-11 10:58 |
| Reporter | normandc | Assigned To | wmayer | ||
| Summary | 0002498: Part Compound: add or remove objects | ||||
| Description | Make it possible to add or remove objects from a Part Compound by drag&drop in the Model tree, exactly like Part Fuse. | ||||
| Steps To Reproduce | Suggested typical work flow to remove an object from a compound: 1. Create a Part Compound from Box, Sphere, Cylinder, Cone... 2. Click on the arrow before the "Compound" label in the Model tree to reveal its content 3. Pick "Cone" and drag it off over the document label, release left mouse button 4. Cone is removed from underneath Compound and placed at the bottom of the Model tree. | ||||
| Tags | Part | ||||
| 2016-04-09 19:53 | normandc | New Issue | |
| 2017-05-07 14:59 | Kunda1 | Tag Attached: Part | |
| 2017-05-10 19:57 | Kunda1 | Project | FreeCAD => Part |
| 2017-08-05 06:00 | silopolis | Note Added: 0009876 | |
| 2017-08-05 13:09 | Kunda1 | Relationship added | related to 0003136 |
| 2017-08-11 10:58 | wmayer | Assigned To | => wmayer |
| 2017-08-11 10:58 | wmayer | Status | new => closed |
| 2017-08-11 10:58 | wmayer | Resolution | open => fixed |
| 2017-08-11 10:58 | wmayer | Fixed in Version | => 0.17 |
| 2017-08-11 10:58 | wmayer | Note Added: 0009887 |
