| 0002499 | Sketcher | Bug | public | 2016-04-09 23:38 | 2017-06-21 20:33 |
| Reporter | hinckel | Assigned To | abdullah | ||
| Summary | 0002499: Crash on cloning operations (sketcher) | ||||
| Description | The application crashes when trying to clone an object onto a specified location (point lock). I am using hexagon objects to create honeycomb patterns. | ||||
| Steps To Reproduce | From the sketch in the attached file, select internal hexagon (select the entire region), then choose the cloning tool and choose as the point to clone onto any of the vertices of the outer construction line hexagon. The application gets killed. Observation. If I clone the same objetc onto a nearbye point and than constrain the center point of the two objects to a coincidence point the operation succeeds and I can change the constraints without problems. | ||||
| Additional Information | OS: "openSUSE Leap 42.1 (x86_64)" Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.16.6698 (Git) Build type: Unknown Branch: master Hash: ca7c5d31a4d61f32a25b71025b14641a6e378328 Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17-dev | ||||
| Tags | Clone | ||||
One more curiosity about the behavior of the cloned object. If I select the interior hexagon and then clone it onto a point located far from the vertex of the outer hexagon such that the cloned object does not intersect the vertex or arest of the outer hexagon and then apply the point constraint to the center point of the cloned hexagon and the vertex of the outer hexagon the construction circle get moved to the right position but the hexagon apparently collpses to a single point. |
stacktrace.log (7,329 bytes)
FreeCAD: SoGroup.cpp:292: virtual SoNode* SoGroup::getChild(int) const: Assertion `(index >= 0) && (index < this->getNumChildren())' failed.
Program received signal SIGABRT, Aborted.
0x00007ffff3faccc9 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
56 ../nptl/sysdeps/unix/sysv/linux/raise.c: No such file or directory.
(gdb) bt
#0 0x00007ffff3faccc9 in __GI_raise (sig=sig@entry=6) at ../nptl/sysdeps/unix/sysv/linux/raise.c:56
#1 0x00007ffff3fb00d8 in __GI_abort () at abort.c:89
#2 0x00007ffff3fa5b86 in __assert_fail_base (fmt=0x7ffff40f6830 "%s%s%s:%u: %s%sAssertion `%s' failed.\n%n", assertion=assertion@entry=0x7ffff3b527a0 "(index >= 0) && (index < this->getNumChildren())",
file=file@entry=0x7ffff3b52622 "SoGroup.cpp", line=line@entry=292, function=function@entry=0x7ffff3b52a20 "virtual SoNode* SoGroup::getChild(int) const") at assert.c:92
#3 0x00007ffff3fa5c32 in __GI___assert_fail (assertion=0x7ffff3b527a0 "(index >= 0) && (index < this->getNumChildren())", file=0x7ffff3b52622 "SoGroup.cpp", line=292,
function=0x7ffff3b52a20 "virtual SoNode* SoGroup::getChild(int) const") at assert.c:101
#4 0x00007ffff38f4fd7 in SoGroup::getChild(int) const () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#5 0x00007fff51f5b205 in SketcherGui::ViewProviderSketch::drawConstraintIcons (this=0x269a7c0) at /home/tomek/GSOC/FreeCAD/src/Mod/Sketcher/Gui/ViewProviderSketch.cpp:2531
#6 0x00007fff51f4f4e2 in SketcherGui::ViewProviderSketch::mouseMove (this=0x269a7c0, cursorPos=..., viewer=0x20d5dc0) at /home/tomek/GSOC/FreeCAD/src/Mod/Sketcher/Gui/ViewProviderSketch.cpp:1025
#7 0x00007ffff754e46a in Gui::ViewProvider::eventCallback (ud=0x269a7c0, node=0x2163070) at /home/tomek/GSOC/FreeCAD/src/Gui/ViewProvider.cpp:195
#8 0x00007ffff38ea95b in SoEventCallback::handleEvent(SoHandleEventAction*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#9 0x00007ffff38fec0c in SoNode::handleEventS(SoAction*, SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#10 0x00007ffff36c4c04 in SoAction::traverse(SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#11 0x00007ffff3814294 in SoChildList::traverse(SoAction*, int, int) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#12 0x00007ffff38f466f in SoGroup::doAction(SoAction*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#13 0x00007ffff39116d7 in SoSeparator::doAction(SoAction*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#14 0x00007ffff7479fd5 in Gui::SoFCUnifiedSelection::handleEvent (this=0x2031960, action=0x16996d0) at /home/tomek/GSOC/FreeCAD/src/Gui/SoFCUnifiedSelection.cpp:323
#15 0x00007ffff38fec0c in SoNode::handleEventS(SoAction*, SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#16 0x00007ffff36c4c04 in SoAction::traverse(SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#17 0x00007ffff3814294 in SoChildList::traverse(SoAction*, int, int) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#18 0x00007ffff38f466f in SoGroup::doAction(SoAction*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#19 0x00007ffff39116d7 in SoSeparator::doAction(SoAction*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#20 0x00007ffff38fec0c in SoNode::handleEventS(SoAction*, SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#21 0x00007ffff36c4c04 in SoAction::traverse(SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#22 0x00007ffff36cf1aa in SoHandleEventAction::beginTraversal(SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#23 0x00007ffff36c57d2 in SoAction::apply(SoNode*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#24 0x00007ffff38320a9 in SoEventManager::actuallyProcessEvent(SoEvent const*) () from /usr/lib/x86_64-linux-gnu/libCoin.so.80
#25 0x00007ffff74ee162 in SIM::Coin3D::Quarter::QuarterWidget::processSoEvent (this=0x20d5dc0, event=0x1803840) at /home/tomek/GSOC/FreeCAD/src/Gui/Quarter/QuarterWidget.cpp:850
#26 0x00007ffff74ec2ac in SIM::Coin3D::Quarter::SoQTQuarterAdaptor::processSoEvent (this=0x20d5dc0, event=0x1803840) at /home/tomek/GSOC/FreeCAD/src/Gui/Quarter/SoQTQuarterAdaptor.cpp:688
#27 0x00007ffff752a151 in Gui::View3DInventorViewer::processSoEventBase (this=0x20d5dc0, ev=0x1803840) at /home/tomek/GSOC/FreeCAD/src/Gui/View3DInventorViewer.cpp:1611
#28 0x00007ffff75060e3 in Gui::NavigationStyle::processSoEvent (this=0x2161140, ev=0x1803840) at /home/tomek/GSOC/FreeCAD/src/Gui/NavigationStyle.cpp:1380
#29 0x00007ffff750c953 in Gui::CADNavigationStyle::processSoEvent (this=0x2161140, ev=0x1803840) at /home/tomek/GSOC/FreeCAD/src/Gui/CADNavigationStyle.cpp:457
#30 0x00007ffff7506034 in Gui::NavigationStyle::processEvent (this=0x2161140, ev=0x1803840) at /home/tomek/GSOC/FreeCAD/src/Gui/NavigationStyle.cpp:1362
#31 0x00007ffff752a121 in Gui::View3DInventorViewer::processSoEvent (this=0x20d5dc0, ev=0x1803840) at /home/tomek/GSOC/FreeCAD/src/Gui/View3DInventorViewer.cpp:1606
#32 0x00007ffff74f1efd in SIM::Coin3D::Quarter::EventFilter::eventFilter (this=0x2159c70, obj=0x20d5dc0, qevent=0x7fffffffc3d0) at /home/tomek/GSOC/FreeCAD/src/Gui/Quarter/EventFilter.cpp:164
#33 0x00007ffff49d2646 in QCoreApplicationPrivate::sendThroughObjectEventFilters(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#34 0x00007ffff4f03e0c in QApplicationPrivate::notify_helper(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#35 0x00007ffff4f0a5dd in QApplication::notify(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#36 0x00007ffff729a069 in Gui::GUIApplication::notify (this=0x7fffffffd3f0, receiver=0x18774b0, event=0x7fffffffc830) at /home/tomek/GSOC/FreeCAD/src/Gui/GuiApplication.cpp:82
#37 0x00007ffff49d24dd in QCoreApplication::notifyInternal(QObject*, QEvent*) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#38 0x00007ffff4f09d93 in QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#39 0x00007ffff4f7e9eb in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#40 0x00007ffff4f7e289 in QApplication::x11ProcessEvent(_XEvent*) () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#41 0x00007ffff4fa5b32 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#42 0x00007fffedee9e04 in g_main_context_dispatch () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#43 0x00007fffedeea048 in ?? () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#44 0x00007fffedeea0ec in g_main_context_iteration () from /lib/x86_64-linux-gnu/libglib-2.0.so.0
#45 0x00007ffff49ff7a1 in QEventDispatcherGlib::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#46 0x00007ffff4fa5be6 in ?? () from /usr/lib/x86_64-linux-gnu/libQtGui.so.4
#47 0x00007ffff49d10af in QEventLoop::processEvents(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#48 0x00007ffff49d13a5 in QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#49 0x00007ffff49d6b79 in QCoreApplication::exec() () from /usr/lib/x86_64-linux-gnu/libQtCore.so.4
#50 0x00007ffff7238ea5 in Gui::Application::runApplication () at /home/tomek/GSOC/FreeCAD/src/Gui/Application.cpp:1810
#51 0x0000000000407382 in main (argc=1, argv=0x7fffffffdda8) at /home/tomek/GSOC/FreeCAD/src/Main/MainGui.cpp:235
hinckel, thank you very much for your bug report. I was able to reproduce it. A stacktrace was added to the attached files. |
This stack trace's additional information: OS: Ubuntu 14.04.3 LTS Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7405 (Git) Build type: Debug Branch: master Hash: de1b04afa6136174dcd89d8a8a1d6aae5e0a847a Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 |
Forum thread: http://forum.freecadweb.org/viewtopic.php?f=10&t=19855 |
A "wild ass guess" or a "pitaco" (pee-tah-cko) (Braz-port) for the behavior described. It might just happen that the solver is being fooled by a trivial solution. A zero length line or an hexagon inscribed in a null diameter circle will satisfy the system of equations. A check might be run to prevent this to happen. |
https://github.com/FreeCAD/FreeCAD/pull/770 |
https://github.com/FreeCAD/FreeCAD/commit/bc6a52ee9497f7192d9fcffc1b56908383630d46 |
| 2016-04-09 23:38 | hinckel | New Issue | |
| 2016-04-09 23:38 | hinckel | File Added: Hexagone.fcstd | |
| 2016-04-09 23:50 | hinckel | Note Added: 0006957 | |
| 2016-04-15 00:43 | tflendrich | File Added: stacktrace.log | |
| 2016-04-15 00:46 | tflendrich | Note Added: 0006970 | |
| 2016-04-15 01:02 | tflendrich | Note Added: 0006971 | |
| 2017-01-13 20:16 | Kunda1 | Note Added: 0007726 | |
| 2017-01-16 18:49 | Kunda1 | Project | FreeCAD => Sketcher |
| 2017-01-16 18:49 | Kunda1 | Status | new => confirmed |
| 2017-02-13 11:01 | hinckel | Note Added: 0008280 | |
| 2017-05-22 16:44 | abdullah | Note Added: 0009084 | |
| 2017-05-22 16:44 | abdullah | Assigned To | => abdullah |
| 2017-05-22 16:44 | abdullah | Status | confirmed => assigned |
| 2017-05-31 04:26 | Kunda1 | Tag Attached: Clone | |
| 2017-06-01 06:34 | wmayer | Status | assigned => closed |
| 2017-06-01 06:34 | wmayer | Resolution | open => fixed |
| 2017-06-01 06:34 | wmayer | Fixed in Version | => 0.17 |
| 2017-06-01 06:34 | wmayer | Note Added: 0009234 | |
| 2017-06-21 20:33 | Kunda1 | Changeset attached | => FreeCAD master bc6a52ee |
