| 0002505 | FreeCAD | Bug | public | 2016-04-14 18:41 | 2016-05-02 17:00 |
| Reporter | pablocaron | Assigned To | |||
| Priority | urgent | Severity | crash | Reproducibility | always |
| Platform | x64 | OS | Linux | OS Version | OpenSUSE 42.1 |
| Summary | 0002505: Seg. Fault when creating a new sketch | ||||
| Description | FreeCAD crashed after update (version: FreeCAD 0.17, Libs: 0.17R7402 (Git) (Packman)) | ||||
| Steps To Reproduce | 1) Open FreeCAD 2) Create a new Part 3) Create a new Active Body 4) Create a new Sketch 5) Draw something (FreeCAD crashes with the message "Can't find Origin for "Part"" 6) If not crashed in previous Step FreeCAD crashes when trying to extrude the sketch. | ||||
I can't reproduce. Can you provide a backtrace? |
Hi ickby, Below you can find the backtrace. Please, tell me if you need additional information. Pablo gdb FreeCAD GNU gdb (GDB; %maintenance_distribution) 7.9.1 Copyright (C) 2015 Free Software Foundation, Inc. License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html> This is free software: you are free to change and redistribute it. There is NO WARRANTY, to the extent permitted by law. Type "show copying" and "show warranty" for details. This GDB was configured as "x86_64-suse-linux". Type "show configuration" for configuration details. For bug reporting instructions, please see: <http://bugs.opensuse.org/> Find the GDB manual and other documentation resources online at: <http://www.gnu.org/software/gdb/documentation/> For help, type "help". Type "apropos word" to search for commands related to "word"... Reading symbols from FreeCAD...Reading symbols from /usr/lib/debug/usr/lib64/FreeCAD/bin/FreeCAD.debug...done. done. (gdb) run Starting program: /usr/bin/FreeCAD Missing separate debuginfos, use: zypper install glibc-debuginfo-2.19-19.1.x86_64 [Thread debugging using libthread_db enabled] Using host libthread_db library "/lib64/libthread_db.so.1". FreeCAD 0.17, Libs: 0.17R7402 (Git) (Packman) © Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2015 ##### #### ### #### # # # # # # # ## #### #### # # # # # #### # # # # # # # ##### # # # # #### #### # # # # # # # # # # # # # # ## ## ## # # #### #### ### # # #### ## ## ## [New Thread 0x7fff87fff700 (LWP 7309)] [New Thread 0x7fff72035700 (LWP 7314)] [New Thread 0x7fff72836700 (LWP 7313)] [New Thread 0x7fff73037700 (LWP 7312)] [New Thread 0x7fff877fe700 (LWP 7310)] [New Thread 0x7fff94987700 (LWP 7308)] [New Thread 0x7fff96043700 (LWP 7307)] [New Thread 0x7fff96efe700 (LWP 7306)] [New Thread 0x7fffd7a0b700 (LWP 7305)] Program received signal SIGSEGV, Segmentation fault. 0x00007ffff4b784f5 in _int_malloc () from /lib64/libc.so.6 (gdb) bt #0 0x00007ffff4b784f5 in _int_malloc () at /lib64/libc.so.6 #1 0x00007ffff4b7a670 in malloc () at /lib64/libc.so.6 0000002 0x00007ffff5153318 in operator new(unsigned long) () at /usr/lib64/libstdc++.so.6 0000003 0x00007ffff6de1a52 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (this=0x597d448, value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x21f480>) at /usr/include/boost/any.hpp:72 0000004 0x00007ffff6de1b29 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x2166de>, this=0x597d440) at /usr/include/boost/any.hpp:175 0000005 0x00007ffff6de1b29 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x21f480>, this=0x597d428) at /usr/include/boost/any.hpp:72 0000006 0x00007ffff6de1b29 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x2166de>, this=0x597d420) at /usr/include/boost/any.hpp:175 0000007 0x00007ffff6de1b29 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x21f480>, this=0x597d408) at /usr/include/boost/any.hpp:72 0000008 0x00007ffff6de1b29 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x2166de>, this=0x597d400) at /usr/include/boost/any.hpp:175 0000009 0x00007ffff6de1b29 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x21f480>, this=0x597d3e8) at /usr/include/boost/any.hpp:72 0000010 0x00007ffff6de1b29 in boost::any::any<boost::any const>(boost::any const&&, boost::disable_if<boost::is_same<boost::any&, boost::any const>, void>::type*) (value=<unknown type in /usr/lib/debug/usr/lib64/FreeCAD/lib/libFreeCADApp.so.debug, CU 0x1dbb5d, DIE 0x2166de>, this=0x597d3e0) at /usr/include/boost/any.hpp:175 |
Which boost version do you use? Seems like this bug: http://forum.freecad.org/viewtopic.php?t=14108 |
The default version in openSUSE 42.1 is boost 1.54. I was trying to install a newer version (1.58) through the package manager. Sadly, uninstalling boost 1.54 brokes several packages (LibreOffice among others). Do you know a way to install a custom boost and make FreeCAD (the package version) to use it? If not, I think that I will have to compile FreeCAD from scratch. Pablo |
Hello, you can download from here: https://software.opensuse.org/package/boost, click on show other versions, Opensuse Leap 42.1 and click on source. Once downloaded open a terminal, go to the download folrder and run $sudo rpm -U "fliname.rpm" |
Althought I've downloaded the 1.60 boost version, FreeCAD has been built against 1.54. Below you can find the detailed list of installed packages. I would appreciate any advice. Pablo zypper se -i boost Cargando datos del repositorio... Leyendo los paquetes instalados... S | Nombre | Resumen | Tipo --+------------------------------------+-------------------------------------------------------------+-------- i | boost-devel | Paquete de desarrollo para Boost C++ | package i | boost-jam | Un make mejorado | package i | boost-license1_54_0 | Licencia de Boost | package i | boost-license1_60_0 | Boost License | package i | libboost_atomic1_54_0 | Run-Time component of boost atomic library | package i | libboost_atomic1_60_0 | Run-Time component of boost atomic library | package i | libboost_chrono1_54_0 | The Boost::Chrono runtime library | package i | libboost_chrono1_60_0 | The Boost::Chrono runtime library | package i | libboost_container1_60_0 | Boost::Container Runtime libraries | package i | libboost_context1_60_0 | Run-Time component of boost context switching library | package i | libboost_coroutine1_60_0 | Boost::Coroutine Runtime libraries | package i | libboost_date_time1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Date.Time | package i | libboost_date_time1_60_0 | Boost::Date.Time Runtime libraries | package i | libboost_filesystem1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Filesystem | package i | libboost_filesystem1_60_0 | Boost::Filesystem Runtime Libraries | package i | libboost_graph1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Graph | package i | libboost_graph1_60_0 | Boost::Graph Runtime Libraries | package i | libboost_graph_parallel1_54_0 | Boost graph::distributed runtime libraries | package i | libboost_graph_parallel1_60_0 | Boost graph::distributed runtime libraries | package i | libboost_iostreams1_54_0 | Bibliotecas de tiempo de ejecución de Boost::IOStreams | package i | libboost_iostreams1_60_0 | Boost::IOStreams Runtime Libraries | package i | libboost_locale1_54_0 | The Boost::Locale runtime library | package i | libboost_locale1_60_0 | The Boost::Locale runtime library | package i | libboost_log1_54_0 | Run-Time component of boost logging library | package i | libboost_log1_60_0 | Run-Time component of boost logging library | package i | libboost_math1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Math | package i | libboost_math1_60_0 | Boost::Math Runtime Libraries | package i | libboost_mpi1_54_0 | Bibliotecas de tiempo de ejecución de Boost::MPI | package i | libboost_mpi1_60_0 | Boost::MPI Runtime libraries | package i | libboost_program_options1_54_0 | Bibliotecas de tiempo de ejecución de Boost::ProgramOptions | package i | libboost_program_options1_60_0 | Boost::ProgramOptions Runtime libraries | package i | libboost_python1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Python | package i | libboost_python1_60_0 | Boost::Python Runtime Libraries | package i | libboost_python1_60_0-32bit | Boost::Python Runtime Libraries | package i | libboost_python3-1_60_0 | Boost::Python Runtime Libraries | package i | libboost_random1_54_0 | The Boost::Random runtime library | package i | libboost_random1_60_0 | The Boost::Random runtime library | package i | libboost_regex1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Regex | package i | libboost_regex1_60_0 | The Boost::Regex runtime library | package i | libboost_serialization1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Serialization | package i | libboost_serialization1_60_0 | Boost::Serialization Runtime Libraries | package i | libboost_serialization1_60_0-32bit | Boost::Serialization Runtime Libraries | package i | libboost_signals1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Signals | package i | libboost_signals1_60_0 | Boost::Signals Runtime Libraries | package i | libboost_system1_54_0 | Bibliotecas de tiempo de ejecución de Boost::System | package i | libboost_system1_60_0 | Boost::System Runtime Libraries | package i | libboost_test1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Test | package i | libboost_test1_60_0 | Boost::Test Runtime Libraries | package i | libboost_thread1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Thread | package i | libboost_thread1_60_0 | Boost::Thread Runtime Libraries | package i | libboost_timer1_54_0 | The Boost::Timer runtime library | package i | libboost_timer1_60_0 | The Boost::Timer runtime library | package i | libboost_wave1_54_0 | Bibliotecas de tiempo de ejecución de Boost::Wave | package i | libboost_wave1_60_0 | Boost::Wave Runtime Libraries | package |
You need to ensure that when you compile freecad the cmake configuration points to the newer boost version. |
The maintainers of Packman repository updated FreeCAD during the last weekend and the issue has been solved, although it still uses boost 1.54. Below you can find the package details and its dependencies. zypper info --requires FreeCAD Cargando datos del repositorio... Leyendo los paquetes instalados... Información para package FreeCAD: --------------------------------- Repositorio: Packman Repository Nombre: FreeCAD Versión: 0.15.99+git20160413.1718-1.4 Arquitectura: x86_64 Proveedor:http://packman.links2linux.de Instalado: Sí Estado: actualizado Tamaño de instalación: 180,7 MiB Resumen:Feature based Parametric Modeler Descripción: FreeCAD is a general purpose feature-based, parametric 3D modeler for CAD, MCAD, CAx, CAE and PLM, aimed directly at mechanical engineering and product design but also fits a wider range of uses in engineering, such as architecture or other engineering specialties. It is 100% Open Source (LGPL2+ license) and extremely modular, allowing for very advanced extension and customization. FreeCAD is based on OpenCasCade, a powerful geometry kernel, features an Open Inventor-compliant 3D scene representation model provided by the Coin 3D library, and a broad Python API. The interface is built with Qt. FreeCAD runs exactly the same way on Windows, Mac OSX, BSD and Linux platforms. Requiere: libc.so.6()(64bit) libc.so.6(GLIBC_2.2.5)(64bit) libc.so.6(GLIBC_2.14)(64bit) libc.so.6(GLIBC_2.4)(64bit) libc.so.6(GLIBC_2.3.4)(64bit) libpthread.so.0()(64bit) libm.so.6()(64bit) libm.so.6(GLIBC_2.2.5)(64bit) libpthread.so.0(GLIBC_2.2.5)(64bit) libstdc++.so.6()(64bit) libstdc++.so.6(GLIBCXX_3.4)(64bit) libstdc++.so.6(CXXABI_1.3)(64bit) libgcc_s.so.1()(64bit) libgcc_s.so.1(GCC_3.0)(64bit) libstdc++.so.6(GLIBCXX_3.4.9)(64bit) libdl.so.2()(64bit) libstdc++.so.6(GLIBCXX_3.4.11)(64bit) libX11.so.6()(64bit) libdl.so.2(GLIBC_2.2.5)(64bit) libstdc++.so.6(GLIBCXX_3.4.15)(64bit) libz.so.1()(64bit) libQtCore.so.4()(64bit) libQtGui.so.4()(64bit) libGL.so.1()(64bit) libfreetype.so.6()(64bit) libstdc++.so.6(CXXABI_1.3.1)(64bit) libQtNetwork.so.4()(64bit) libQtXml.so.4()(64bit) libGLU.so.1()(64bit) python-xml libpython2.7.so.1.0()(64bit) libboost_system.so.1.54.0()(64bit) libstdc++.so.6(GLIBCXX_3.4.5)(64bit) libboost_program_options.so.1.54.0()(64bit) libstdc++.so.6(GLIBCXX_3.4.18)(64bit) libQtOpenGL.so.4()(64bit) libQtWebKit.so.4()(64bit) libQtSvg.so.4()(64bit) libgcc_s.so.1(GCC_3.4)(64bit) libstdc++.so.6(CXXABI_1.3.5)(64bit) libboost_regex.so.1.54.0()(64bit) libCoin.so.80()(64bit) python-pyside libTKBO.so.10()(64bit) libTKBRep.so.10()(64bit) libTKBin.so.10()(64bit) libTKBool.so.10()(64bit) libTKCAF.so.10()(64bit) libTKFeat.so.10()(64bit) libTKFillet.so.10()(64bit) libTKG2d.so.10()(64bit) libTKG3d.so.10()(64bit) libTKGeomAlgo.so.10()(64bit) libTKGeomBase.so.10()(64bit) libTKHLR.so.10()(64bit) libTKIGES.so.10()(64bit) libTKLCAF.so.10()(64bit) libTKMath.so.10()(64bit) libTKMesh.so.10()(64bit) libTKMeshVS.so.10()(64bit) libTKOffset.so.10()(64bit) libTKPrim.so.10()(64bit) libTKSTEP.so.10()(64bit) libTKSTEPAttr.so.10()(64bit) libTKSTEPBase.so.10()(64bit) libTKSTL.so.10()(64bit) libTKShHealing.so.10()(64bit) libTKTopAlgo.so.10()(64bit) libTKXCAF.so.10()(64bit) libTKXDEIGES.so.10()(64bit) libTKXDESTEP.so.10()(64bit) libTKXSBase.so.10()(64bit) libTKernel.so.10()(64bit) Assembly.so()(64bit) Drawing.so()(64bit) Fem.so()(64bit) Image.so()(64bit) Import.so()(64bit) Inspection.so()(64bit) Mesh.so()(64bit) Part.so()(64bit) PartGui.so()(64bit) Path.so()(64bit) Points.so()(64bit) Raytracing.so()(64bit) Robot.so()(64bit) Sketcher.so()(64bit) SketcherGui.so()(64bit) Spreadsheet.so()(64bit) _PartDesign.so()(64bit) libDriver.so()(64bit) libDriverDAT.so()(64bit) libDriverSTL.so()(64bit) libDriverUNV.so()(64bit) libFreeCADApp.so()(64bit) libFreeCADBase.so()(64bit) libFreeCADGui.so()(64bit) libMEFISTO2.so()(64bit) libSMDS.so()(64bit) libSMESH.so()(64bit) libSMESHDS.so()(64bit) libStdMeshers.so()(64bit) libboost_python.so.1.54.0()(64bit) libboost_signals.so.1.54.0()(64bit) libzipios.so.0()(64bit) python-numpy libshiboken-python2.7.so.1.2()(64bit) libspnav.so.0()(64bit) libxerces-c-3.1.so()(64bit) python-cxx libCoin80 == 3.9.99+hg20150827.1730 python-pivy == 0.5.0+hg20101206.2327 libSoQt20 == 1.5.99+hg20111204.2153 /sbin/ldconfig |
FreeCAD: master 1e061b5c 2016-04-26 19:37:32 Committer: wmayer Details Diff |
Fix boost::any bug with Boost 1.54. and set BOOST_MIN_VERSION to 1.48. Fixes: - /view.php?id=0002505 - http://forum.freecad.org/viewtopic.php?f=13&t=15310 - http://forum.freecad.org/viewtopic.php?f=3&t=15400 - http://forum.freecad.org/viewtopic.php?f=10&t=14108 |
Affected Issues 0002505 |
| mod - CMakeLists.txt | Diff File | ||
| mod - src/App/CMakeLists.txt | Diff File | ||
| mod - src/App/ObjectIdentifier.h | Diff File | ||
| mod - src/App/Property.h | Diff File | ||
| mod - src/Mod/Assembly/App/CMakeLists.txt | Diff File | ||
| mod - src/Mod/Assembly/App/opendcm/core/constraint.hpp | Diff File | ||
| add - src/boost_any_1_55.hpp | Diff File | ||
| 2016-04-14 18:41 | pablocaron | New Issue | |
| 2016-04-14 19:14 | ickby | Note Added: 0006967 | |
| 2016-04-14 19:43 | pablocaron | Note Added: 0006968 | |
| 2016-04-14 19:44 | pablocaron | Note Edited: 0006968 | |
| 2016-04-14 19:54 | ickby | Note Added: 0006969 | |
| 2016-04-15 13:34 | pablocaron | Note Added: 0006973 | |
| 2016-04-15 14:06 | EduardoJV | Note Added: 0006974 | |
| 2016-04-15 14:31 | pablocaron | Note Added: 0006975 | |
| 2016-04-17 18:10 | ickby | Note Added: 0006985 | |
| 2016-04-19 12:43 | pablocaron | Note Added: 0006990 | |
| 2016-05-02 17:00 | wmayer | Changeset attached | => FreeCAD Master master 1e061b5c |
| 2016-05-02 17:00 | wmayer | Status | new => closed |
| 2016-05-02 17:00 | wmayer | Resolution | open => fixed |
| 2016-05-02 17:00 | wmayer | Fixed in Version | => 0.17 |
