| 0002511 | PartDesign | Bug | public | 2016-04-16 14:11 | 2019-07-30 22:45 |
| Reporter | ulrich1a | Assigned To | abdullah | ||
| Summary | 0002511: Failing adding xy-datum-plane in example-cylinder | ||||
| Description | This report is about "PartDesign Next" in 0.17 development version Deepsoic did post an cylinder with tangent datum planes. It is not possible to add a xy-datum-plane to the body. Nothing happens at clicking the button, no warnings, no new datum-plane. | ||||
| Steps To Reproduce | - open the file below - select the xy-plane in the body - click create datum-plane in the task-view Nothing happens. | ||||
| Additional Information | OS: Debian GNU/Linux 8.4 (jessie) Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7405 (Git) Build type: Release Branch: remotes/origin/master Hash: de1b04afa6136174dcd89d8a8a1d6aae5e0a847a Python version: 2.7.9 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.8.0.oce-0.17 | ||||
Workaround (and possibly, explanation): Double-click the body to make it active. Then, datum planes can be made. |
There is a function "UnifiedDatumCommand" that calls PartDesignGui::getBody which shows up a message dialog that there's no active body. But therefore the parameter should be set to "!bEditSelected" instead of "false". |
@wmayer can you offer some insight how to proceed with this ticket? Shall i post it to the forum? Or perhaps mention something to ickby ? |
The lack of datum plane is not a bug. Bug is that datum plane button does nothing at all, IMO. Either a message should pop up, or a line should be printed to console. Or the button should be simply disabled until one activates a body. |
I agree with DeepSOIC. A pop-up added in: https://github.com/FreeCAD/FreeCAD/pull/792 |
https://github.com/FreeCAD/FreeCAD/commit/4b042536f8c93caae09040a32473343ac3b24775 |
| 2016-04-16 14:11 | ulrich1a | New Issue | |
| 2016-04-16 14:11 | ulrich1a | File Added: datum planes attached to cylinder.FCStd | |
| 2016-04-16 14:45 | DeepSOIC | Note Added: 0006977 | |
| 2016-04-16 16:21 | wmayer | Note Added: 0006980 | |
| 2017-02-19 14:23 | Kunda1 | Product Version | => 0.17 |
| 2017-02-19 14:56 | Kunda1 | Note Added: 0008369 | |
| 2017-02-19 19:00 | DeepSOIC | Note Added: 0008372 | |
| 2017-03-10 06:32 | Kunda1 | Target Version | => 0.17 |
| 2017-05-30 22:18 | abdullah | Note Added: 0009202 | |
| 2017-05-30 22:18 | abdullah | Assigned To | => abdullah |
| 2017-05-30 22:18 | abdullah | Status | new => assigned |
| 2017-05-31 01:02 | wmayer | Status | assigned => closed |
| 2017-05-31 01:02 | wmayer | Resolution | open => fixed |
| 2017-05-31 01:02 | wmayer | Fixed in Version | => 0.17 |
| 2017-05-31 01:02 | wmayer | Note Added: 0009211 | |
| 2019-07-30 22:45 | Kunda1 | Changeset attached | => FreeCAD master 4b042536 |
