| 0002516 | FreeCAD | Bug | public | 2016-04-20 09:13 | 2018-08-26 15:21 |
| Reporter | NumOpen | Assigned To | |||
| Priority | none | Severity | minor | Reproducibility | have not tried |
| Platform | Intel 64-bit | OS | Windows | OS Version | 7 |
| Summary | 0002516: Microsoft Visual C++ 2013 is included in the setup package | ||||
| Description | I installed FreeCAD version 0.16.6700 on Windows 7. The installer added Microsoft Visual C++ 2013. I think you shouldn't add Microsoft DLL in the installer because you add a proprietary software in the free software package and because we have no choice to accept or not it. It's like with crapwares in installers. It would be better that the installer tests if Microsoft Visual C++ 2013 is already installed and if not, DOWNLOAD it and then install it. | ||||
| Tags | distribution specific, Win | ||||
> I think you shouldn't add Microsoft DLL in the installer because you add a proprietary software in the free software package and because we have no choice to accept or not it. It's like with crapwares in installers. But this installs the required runtime and without it FreeCAD won't even start and only gives a cryptic error message that 99% of the users won't understand. If the runtime is already installed then the included installer won't do anything. > It would be better that the installer tests if Microsoft Visual C++ 2013 is already installed and if not, DOWNLOAD it and then install it. That would be definitely worse because how would an average user know which re-distributable to install? There is one for every compiler version and also Win32 and Win64 architecture. So, it would quite difficult to find the right one. The only thing that could be done is making an option to the installer where the user can switch it on or off. |
That would be definitely worse because how would an average user know which re-distributable to install? -> 1) You can explain it on your website, on the download page, with the necessary links toward VC++. -> 2) The installer can test which version of VC++ is already installed and if necessary, download and install it automatically. The user will not have to do anything, the installation will be automatic as in the current solution but you will not add a proprietary software in the free software package. A lot of others free softwares do like that, with JAVA or VC++. |
And with this method, your package will be smaller and if VC++ is already installed, the users won't download it, it's more ecologic :) |
https://kobyk.wordpress.com/2008/04/12/deploying-the-visual-c-libraries-with-an-nsis-installer/ http://stackoverflow.com/questions/12206314/detect-if-visual-c-redistributable-for-visual-studio-2012-is-installed |
See also: http://forum.freecad.org/viewtopic.php?f=4&t=15786&p=125476#p125476 |
> It would be better that the installer tests if Microsoft Visual C++ 2013 is already installed and if not, DOWNLOAD it and then install it. It would also make FreeCAd uninstallable - or annoying to install - on machines without internet access, which is the case in a big part of the world. I also think the best way would be to make this an untickable option in the installer... |
If you can download FreeCAD, you've got an access to internet and you can download MSVC++ too. You could add a message on FreeCAD download page, with a link toward MSVC++ download page. I think it's not a good solution to include MSVC++ because you put proprietary software into a free software package and because we must download it even it's unnecessary. A good solution is to test if MSVC++ is already installed and if not, download and install it, like Shareaza, PHPServer, Hexchat, Handbrake... are doing. |
I know all this looks obvious for someone used to open-source software, but there are still a lot of countries where people are sharing software on usb keys, sometimes whole "packages" made by someone out there who might not read the full instructions on the website. If we did this we would certainly cause problems for many people outside the industrialized world. |
If they can put and share FreeCAD on an USB key, they can do it with MSVC++ too, even if the two softwares are separated. They are enough intelligent outside the industrialized world to do it. |
@yorik fate of this ticket? |
Well I don't think any of us intends to do anything about it, so it might be best to close it as "won't fix"... However, as I suggested above, the visual c++ package could also be added to the install screen as an untickable option: https://www.freecad.org/wiki/images/1/1b/Freecad-windows-install-03.jpg But I never touched the windows installer, not sure what is involved or if it is a good idea or not. |
@sgrogan1 are you interested in tackling this ? Specifically:
@Kunda1 It's fine to assign this to me. It's a bit of a balancing act though. See Here: https://forum.freecad.org/viewtopic.php?f=8&t=14211 Maybe some warning text in the dialog that @yorik posted could work. FreeCAD doesn't run without the redistributable, so allowing 1% of users download it independently, means forcing 99% of users to do it manually. You can target for 0.17 release. |
@yorik what do you think? |
@Kunda1 I'm fine with what sgrogan says (add a warning text). |
@sgrogan1 what should the text read? And where in the source should it be added. I'll be happy to add it and submit a PR. |
@kunda1 can you target for 0.18? I agree with wmayer more and more. I think we could eventually have a warning that proprietary software will be installed continue or quit. On windows these are really the only options. For 0.17 I will keep this from the developer builds "These builds require https://www.microsoft.com/en-us/download/details.aspx?id=40784 If you've installed an x64 version before you most likely have it already. x86 (32-bit) users will need to install it." or the like. |
Targeted to 0.18 per @sgrogan1 request |
https://github.com/FreeCAD/FreeCAD/commit/d45135e46c45e6989969b17fa5f7c6c1264a74b5 Installation of runtime libraries is now optional and off by default. |
| 2016-04-20 09:13 | NumOpen | New Issue | |
| 2016-04-21 10:03 | wmayer | Note Added: 0006992 | |
| 2016-04-21 10:09 | NumOpen | Note Added: 0006993 | |
| 2016-04-21 10:10 | NumOpen | Note Edited: 0006993 | |
| 2016-04-21 10:26 | NumOpen | Note Added: 0006994 | |
| 2016-04-21 10:29 | NumOpen | Note Edited: 0006993 | |
| 2016-04-22 17:09 | wmayer | Note Added: 0006996 | |
| 2016-05-18 17:33 | wmayer | Note Added: 0007111 | |
| 2016-05-29 01:39 | yorik | Note Added: 0007122 | |
| 2016-05-29 07:38 | NumOpen | Note Added: 0007124 | |
| 2016-05-29 14:25 | yorik | Note Added: 0007125 | |
| 2016-05-29 15:01 | NumOpen | Note Added: 0007126 | |
| 2016-05-29 15:02 | NumOpen | Note Edited: 0007126 | |
| 2016-05-30 13:09 | wmayer | Assigned To | => sgrogan |
| 2016-05-30 13:09 | wmayer | Status | new => assigned |
| 2017-03-02 18:07 | Kunda1 | Tag Attached: distribution specific | |
| 2017-03-02 18:07 | Kunda1 | Tag Attached: Win | |
| 2017-07-12 12:45 | Kunda1 | Note Added: 0009738 | |
| 2017-07-12 12:46 | Kunda1 | Tag Attached: #pending | |
| 2017-07-12 15:46 | yorik | Note Added: 0009740 | |
| 2017-07-12 16:48 | Kunda1 | Note Added: 0009744 | |
| 2017-07-12 16:48 | Kunda1 | Assigned To | sgrogan => user2853 |
| 2017-07-12 22:10 |
Note Added: 0009751 | |
| 2017-07-12 22:11 |
Note Edited: 0009751 | |
| 2017-07-12 22:31 | Kunda1 | Target Version | => 0.17 |
| 2017-09-26 15:17 | Kunda1 | Note Added: 0010195 | |
| 2017-09-26 16:28 | yorik | Note Added: 0010198 | |
| 2017-09-27 12:09 | Kunda1 | Note Added: 0010200 | |
| 2018-02-08 00:35 |
Note Added: 0010932 | |
| 2018-02-08 09:01 | wmayer | Priority | normal => none |
| 2018-02-08 09:01 | wmayer | Target Version | 0.17 => |
| 2018-02-08 09:25 | Kunda1 | Target Version | => 0.18 |
| 2018-02-08 09:25 | Kunda1 | Note Added: 0010933 | |
| 2018-03-14 12:28 | wmayer | Fixed in Version | => 0.17 |
| 2018-03-14 12:28 | wmayer | Target Version | 0.18 => 0.17 |
| 2018-03-14 12:28 | wmayer | Note Added: 0011039 | |
| 2018-03-14 12:28 | wmayer | Status | assigned => closed |
| 2018-03-14 12:28 | wmayer | Resolution | open => fixed |
| 2018-08-26 15:21 | Kunda1 | Tag Detached: #pending |
