| 0002517 | PartDesign | Bug | public | 2016-04-21 08:58 | 2017-09-13 11:23 |
| Reporter | wmayer | Assigned To | ickby | ||
| Summary | 0002517: Some oddities with shape binder | ||||
| Description | When I create a body and then click on the shape binder icon I get flooded with the messages: not a dag exception in DAGView::Model::updateSlot() With a press on Cancel the added ShapeBinder object won't be deleted. And since it's in edit mode you first have to leave edit mode so that it can be manually deleted. When I create e.g. a standard box before then I can safely invoke the shape binder. Now when pressing the "Add geometry" button I can select a face of the box but then in the output window an error essage comes up: Unhandled unknown exception caught in GUIApplication::notify. Any attempts to add further geometries or remove the added one doesn't work. You always get the above error message. When clicking on OK an occ error comes up: Access violation at address 0x000000 during READ operation After pressing Cancel to leave the shape binder and you do a double-click on the icon the error comes up "Unknown C++ exception" but it enters into label edit mode instead of entering the shape binder edit mode as one would assume with the bold text of its context-menu. If I open the context-menu and invoke Edit shape binder again this error message comes up: Unhandled unknown exception caught in GUIApplication::notify. After trying a while I do not even know what the shape binder is good for as wasn't able to get it working at all. | ||||
| Tags | DAG, shapebinder | ||||
The crash happens inside ShapeBinder::getFilterdReferences. The list 'objs' contains a single element which is a nullptr that's why it crashes at: while(!objs[index]->isDerivedFrom(Part::Feature::getClassTypeId()) && index < objs.size()) So, the actual bug already happens in TaskShapeBinder::referenceSelected where it sets the selection: static_cast<PartDesign::ShapeBinder*>(vp->getObject())->Support.setValue(obj, refs); 'obj' is a nullptr here. |
I can't reproduce. Was this fixed? |
@wmayer can you still reproduce this? |
Further feedback needed to confirm whether the issue still exists or not. |
@wmayer please weigh in when you have a moment. thanks! |
The not-a-DAG error messages are still there and also trying to add geometry to the shape binder leads to a crash. The only point that is fixed so far is pressing the Cancel button to delete the shape binder object. |
https://github.com/FreeCAD/FreeCAD/commit/756ed3381e65e9744790710c4a6338a64394e93e fixes the crash in ShapeBinder::getFilterdReferences |
The DAG issue is fixed in https://github.com/FreeCAD/FreeCAD/commit/f663a754c85cfe39aa4850827fecae7f524e4ae5 |
| 2016-04-21 08:58 | wmayer | New Issue | |
| 2016-04-21 08:58 | wmayer | Status | new => assigned |
| 2016-04-21 08:58 | wmayer | Assigned To | => ickby |
| 2016-04-24 16:06 | wmayer | Note Added: 0007000 | |
| 2017-02-17 10:56 | Kunda1 | Tag Attached: DAG | |
| 2017-06-18 00:07 | normandc | Note Added: 0009435 | |
| 2017-06-21 10:34 | Kunda1 | Tag Attached: shapebinder | |
| 2017-06-21 10:36 | Kunda1 | Note Added: 0009476 | |
| 2017-06-21 10:37 | Kunda1 | Target Version | => 0.17 |
| 2017-07-09 20:41 | normandc | Status | assigned => feedback |
| 2017-07-09 20:41 | normandc | Note Added: 0009699 | |
| 2017-08-13 16:58 | Kunda1 | Note Added: 0009917 | |
| 2017-08-30 18:06 | wmayer | Note Added: 0010049 | |
| 2017-08-30 18:06 | wmayer | Status | feedback => assigned |
| 2017-09-10 12:20 | wmayer | Note Added: 0010102 | |
| 2017-09-13 11:23 | wmayer | Status | assigned => closed |
| 2017-09-13 11:23 | wmayer | Resolution | open => fixed |
| 2017-09-13 11:23 | wmayer | Fixed in Version | => 0.17 |
| 2017-09-13 11:23 | wmayer | Note Added: 0010111 |
