| 0002522 | PartDesign | Bug | public | 2016-04-25 01:22 | 2021-02-20 13:58 |
| Reporter | Freedom1 | Assigned To | realthunder | ||
| Priority | normal | Severity | major | Reproducibility | sometimes |
| OS | Fedora Linux | OS Version | 23 _ 64 bit | ||
| Summary | 0002522: part design fillet and chamfer tool will not reproduce same edge# or face# | ||||
| Description | Bug appears upon reload of part or regeneration of part due to deleting chamfers or fillets in the model on subsequent chamfers or fillets down the feature list. The identity of each edge or face seems to be determined uniquely upon regeneration of model. By removing features earlier in the model list the edge# or face# identity seems to become renumbered, thereby causing the associated fillet or chamfer to attach to other edges or faces than originally selected. | ||||
| Steps To Reproduce | Take a given model with about a dozen features: a pad, cylinders boolean subtractions for holes, fillets, chamfers Then remove some features, save part, close part, reload part. Frequently upon reloading the features reassign to the edge# or face# with the same number, but whose identity is different from the original model (a different edge or face). | ||||
| Additional Information | Fedora repository FreeCAD version 0.15 4671 Git | ||||
| Tags | toponaming | ||||
| duplicate of | 0000922 | assigned | realthunder | FreeCAD | Topological Naming |
I cannot reproduce this bug. Can you please provide step-by-step instructions on how to reproduce, and provide a sample file? |
Your FreeCAD version is obsolete. 0.16.670x was released in April of this year. Therefore bugs should be reported for the current stable version, not 0.15. In any case this sounds like the topology naming problem. 0000922 |
@Freedom1 please respond by: 1) Testing on the current stable version of FreeCAD (at this time it's 0.16) and reporting back 2) Sharing the contents of Help > About FreeCAD > Copy to clipboard |
Reminder sent to: wmayer @wmayer do you mind weighing in on this ticket? |
@kunda I would add a topology naming tag. |
I'm assigning them to jnxd. |
Closing in favor of 0000922 |
| 2016-04-25 01:22 | Freedom1 | New Issue | |
| 2016-04-25 01:22 | Freedom1 | File Added: G-R02.fcstd | |
| 2016-04-27 12:19 | ickby | Relationship added | child of 0000922 |
| 2016-05-09 22:46 | ezzieyguywuf | Note Added: 0007074 | |
| 2016-06-25 21:30 | normandc | Note Added: 0007159 | |
| 2016-06-25 21:30 | normandc | Note Edited: 0007159 | |
| 2017-01-28 12:03 | Kunda1 | Note Added: 0008047 | |
| 2017-01-28 12:03 | Kunda1 | Status | new => feedback |
| 2017-01-28 12:03 | Kunda1 | Tag Attached: #pending | |
| 2017-02-14 16:17 | Kunda1 | Note Added: 0008292 | |
| 2017-05-30 22:43 | abdullah | Note Added: 0009203 | |
| 2017-05-30 22:56 | Kunda1 | Assigned To | => jnxd |
| 2017-05-30 22:56 | Kunda1 | Status | feedback => assigned |
| 2017-05-30 22:56 | Kunda1 | Tag Detached: #pending | |
| 2017-05-30 22:57 | Kunda1 | Note Added: 0009204 | |
| 2021-02-20 13:57 | Kunda1 | Tag Attached: toponaming | |
| 2021-02-20 13:58 | Kunda1 | Assigned To | jnxd => realthunder |
| 2021-02-20 13:58 | Kunda1 | Status | assigned => closed |
| 2021-02-20 13:58 | Kunda1 | Resolution | open => duplicate |
| 2021-02-20 13:58 | Kunda1 | Note Added: 0015385 | |
| 2021-02-20 13:58 | Kunda1 | Relationship replaced | duplicate of 0000922 |
