| 0002541 | FreeCAD | Bug | public | 2016-05-09 14:14 | 2017-07-08 15:53 |
| Reporter | sliptonic | Assigned To | |||
| Platform | All | ||||
| Summary | 0002541: Part.Wire.makeoffset() doesn't offset single edge. | ||||
| Description | Part.Wire.makeoffset doesn't correctly offset a single edge. If a wire contains multiple edges, the offset is correct but if it contains only a single edge, no offset is created. | ||||
| Steps To Reproduce | Create a new file and add a Part cube. Select two vertical faces (side and right) of the cube. run the attached macro sortpathtest and observe the output. With two faces selected, offset is possible and 9 edges are returned. this is correct since it includes the arcs around the ends of the faces. Now select just one face and repeat. A shape object is returned but it includes no edges. No offset was done. I would expect a shape object with 6 edges. Output with 2 faces: wires in slice:1 Line Line edgelist: [<Edge object at 0x348de50>, <Edge object at 0x272f440>] edges in edgelist:2 newwire: <Wire object at 0x2b8f220> edges in newwire:2 offset: <Shape object at 0x31c8850> edges in offset:9 output with 1 face: Line edgelist: [<Edge object at 0x3247c80>] edges in edgelist:1 newwire: <Wire object at 0x2b35610> edges in newwire:1 offset: <Shape object at 0x2db8540> edges in offset:0 | ||||
| Additional Information | OS: Linux Mint 17.3 Rosa Word size of OS: 64-bit Word size of FreeCAD: 64-bit Version: 0.17.7514 +17 (Git) Build type: Unknown Branch: pathimprove Hash: f20a1ed9055f09880b26e00fa841b062bf679c7d Python version: 2.7.6 Qt version: 4.8.6 Coin version: 4.0.0a OCC version: 6.7.0 | ||||
This offsetting is used widely in Path workbench for calculating tool position. When I said that I'd expect a wire with 6 edges, that is based on how the offset function currently works and not how I would desire it. It would be better if the option existed to offset open wires and only create edges for one side of the base wire rather tnan offsetting all the way around. If that were the case, I would expect the result to contain a Shape object with a single edge offset from the reference wire by the amount specified. |
As mentioned in 0002542 the offset algorithm only works for planar wires or edges. However, for a single straight line this plane is not unique and thus it's impossible for the algorithm to determine in which direction to offset. |
@sliptonic do you mind re-upping the attachment? It was lost in the tracker restore :( Also do you mind opening a thread for this ticket as well so it gets a little more exposure? Thanks in advance! |
@sliptonic ping |
I don't think I've got it either anymore. Honestly, I don't think it's worth keeping open. We're using PathArea for almost all the offsetting now. Let's close this for now. If issue resurfaces in another context, we'll have a better test case. |
Makes sense. Thanks! Closing per @sliptonic |
| 2016-05-09 14:14 | sliptonic | New Issue | |
| 2016-05-09 14:14 | sliptonic | File Added: sortpathtest.FCMacro | |
| 2016-05-09 14:43 | sliptonic | Note Added: 0007073 | |
| 2016-05-12 20:38 | wmayer | Note Added: 0007085 | |
| 2017-01-18 01:06 | Kunda1 | Relationship added | related to 0002542 |
| 2017-06-15 12:43 | Kunda1 | Note Added: 0009386 | |
| 2017-06-15 12:43 | Kunda1 | Status | new => feedback |
| 2017-07-08 14:47 | Kunda1 | Note Added: 0009683 | |
| 2017-07-08 15:35 | sliptonic | Note Added: 0009684 | |
| 2017-07-08 15:35 | sliptonic | Status | feedback => new |
| 2017-07-08 15:53 | Kunda1 | Status | new => closed |
| 2017-07-08 15:53 | Kunda1 | Resolution | open => no change required |
| 2017-07-08 15:53 | Kunda1 | Note Added: 0009686 |
