| 0002543 | Arch | Feature | public | 2016-05-12 01:31 | 2021-02-06 06:28 |
| Summary | 0002543: Implement GBXML export | ||||
| Description | Implement the possibility to export a BIM model as GBXML | ||||
| Additional Information | Started in https://github.com/FreeCAD/FreeCAD/blob/master/src/Mod/Arch/importGBXML.py Downstream ticket: https://github.com/yorikvanhavre/BIM_Workbench/issues/6 Bountysource: https://www.bountysource.com/issues/65465675-implement-gbxml-export | ||||
| Tags | Bountysource, fundable, funded | ||||
Some more ideas to implement before actual export: - Add some general settings to the project (site or building), maybe linked/embedded osm file? - Add tool to subdivide solid faces with another solid (useful for FEM too) - Base everything on spaces. What gets exported are spaces. - Ability to mark faces of spaces as 1) shared 2) exterior 3) ground 4) window - Ability to define thermal zones and add spaces to these thermal zones (use floors maybe?) - Ability to retrieve a building's floor area Also check the .osm format of openstudio. Openstudio itself will allow to set many more settings and do the necessary export to radiance and energyplus. Basically from FreeCAD we should be able to do the same as what sketchup does, that is: - create simple geometry (spaces) - define what is shared wall, what is window, etc (a way to do that easily/automatically?) - create shadowing devices (not sure how to do that, creates non-solid/manifold objects) - give these spaces a name, a use/function, a thermal zone. |
Added https://github.com/yorikvanhavre/BIM_Workbench/issues/6 to the summary |
This ticket has been migrated to GitHub as issue 5654. |
FreeCAD: master 68615743 2016-10-07 03:35:45 Details Diff |
Arch: Added several properties to Equipment, Space, Floor & Site needed for gbXML - issue 0002543 |
Affected Issues 0002543 |
| mod - src/Mod/Arch/ArchEquipment.py | Diff File | ||
| mod - src/Mod/Arch/ArchFloor.py | Diff File | ||
| mod - src/Mod/Arch/ArchSite.py | Diff File | ||
| mod - src/Mod/Arch/ArchSpace.py | Diff File | ||
| mod - src/Mod/Arch/importGBXML.py | Diff File | ||
| 2016-05-12 01:31 | yorik | New Issue | |
| 2016-05-12 01:31 | yorik | Status | new => assigned |
| 2016-05-12 01:31 | yorik | Assigned To | => yorik |
| 2016-05-12 01:33 | yorik | Target Version | => 0.17 |
| 2016-10-06 22:45 | yorik | Note Added: 0007346 | |
| 2016-10-06 22:47 | yorik | Note Edited: 0007346 | |
| 2016-10-07 01:36 | yorik | Changeset attached | => FreeCAD Master master 68615743 |
| 2017-10-22 20:51 | wmayer | Target Version | 0.17 => |
| 2018-01-12 15:09 | yorik | Target Version | => 0.18 |
| 2018-10-04 12:54 | Kunda1 | Additional Information Updated | |
| 2018-10-04 12:54 | Kunda1 | Note Added: 0011918 | |
| 2018-11-07 21:11 | yorik | Additional Information Updated | |
| 2018-11-07 21:12 | yorik | Tag Attached: Bountysource | |
| 2019-02-15 00:25 | yorik | Target Version | 0.18 => 0.19 |
| 2019-04-29 14:01 | yorik | Tag Attached: funded | |
| 2019-04-29 14:02 | yorik | Tag Attached: fundable | |
| 2021-02-06 06:28 | abdullah | Target Version | => 0.20 |
