| 0002544 | FEM | Bug | public | 2016-05-12 17:03 | 2019-01-13 11:16 |
| Reporter | HoWil | Assigned To | |||
| Status | closed | Resolution | open | ||
| Platform | Linux x64 | OS | Ubuntu | OS Version | Ubuntu 16.04 |
| Summary | 0002544: Showing results should show/redraw only the mesh for current simulation | ||||
| Description | When using multiple FEM simulations in one FreeCAD model the showing results button for one simulation also redraws the mesh of the other simulations. Only the mesh from the actual simulation should be redrawn (shown). All other meshes should keep hidden if the were switched to hidden. This behavior is annoying when one switched hidden all elements of other simulations to show only the results from one special simulation and then all other meshes were shown also. | ||||
| Steps To Reproduce | Draw a cube in Part WB. Add first simulation. Run the simulation. Add second simulation. Run the second simulation. Hide both meshes. Draw a result of the first simulation. Both meshes will be drawn!!!!! | ||||
| Tags | FEM | ||||
| 2016-05-12 17:03 | HoWil | New Issue | |
| 2016-05-12 17:03 | HoWil | File Added: Two_simulations_mesh_hiding_problem.fcstd | |
| 2016-05-12 17:09 | HoWil | Tag Attached: FEM | |
| 2016-05-12 17:10 | HoWil | Tag Attached: solution results | |
| 2016-07-28 23:40 | berndhahnebach | Note Added: 0007227 | |
| 2017-01-24 12:12 | berndhahnebach | Status | new => closed |
| 2017-01-24 12:38 | Kunda1 | Note Added: 0007956 | |
| 2017-01-24 12:38 | Kunda1 | Fixed in Version | => 0.17 |
| 2019-01-13 11:16 | Kunda1 | Tag Detached: solution results |
