| 0002545 | FEM | Feature | public | 2016-05-12 17:08 | 2019-01-13 11:16 |
| Reporter | HoWil | Assigned To | |||
| Status | closed | Resolution | open | ||
| Platform | Linux x46 | OS | Ubuntu | OS Version | 16.04 |
| Summary | 0002545: Show results when double click on results entry in model tree view | ||||
| Description | Show results when double click on results entry in model tree view. Otherwise one has always to select the results and then click the "Show results information of an analysis (S, R)" button which is lame. Double clicking on a FEM simulation entry also opens the FEM workbench. A behavior similar to this would be nice for showing the results. | ||||
| Tags | FEM, tree view | ||||
Works in 0.17.8048 If the analysis is active on double click on a result object the result task panel gets opened. Keep in mind the analysis needs to be activated to open a result widget. For me this could be closed! |
modified ticket to show it was fixed in 0.17 |
| 2016-05-12 17:08 | HoWil | New Issue | |
| 2016-05-12 17:08 | HoWil | Tag Attached: FEM | |
| 2016-05-12 17:09 | HoWil | Tag Attached: tree view | |
| 2016-05-12 17:10 | HoWil | Tag Attached: solution results | |
| 2016-07-28 23:34 | berndhahnebach | Note Added: 0007226 | |
| 2017-01-24 12:03 | berndhahnebach | Status | new => closed |
| 2017-01-24 12:37 | Kunda1 | Note Added: 0007955 | |
| 2017-01-24 12:37 | Kunda1 | Fixed in Version | => 0.17 |
| 2019-01-13 11:16 | Kunda1 | Tag Detached: solution results |
